RacingBrake stainless brake pistons installed
Thinking of selling my FLT-A2 CO's and still NIB Essex AP kit that I never put on the car....
Back to topic... what's the torque for the bolts holding the caliper halves?
I have a spare set of front calipers that could use dust boots. I will likely do the same now. Waiting to see some more track-use updates.
Oh wait...I'm sponsored by the same people. LOL
they could make titanium pistons but i don't think anyone would afford it.
i don't see a big advantage of titanium pistons over stainless since stainless is a worse heat conductor. only advantage of titanium is lighter and higher melting point, but i don't see stainless pistons melting. i have seen aluminum pistons melt, but he did run the pads all the half way down the backing plates. i think most use two piece pistons when they use titanium.
here are some pictures of titanium pistons inserts.
i think most of you guys have seen this test before. i was going to do a similar test but use brake fluid and thermometer inside the fluid. but i got lazy and just installed the pistons.
How does that apply to the titanium shims behind the pads? I thought the differential in thermal conductivity was the factor and not weight. Would that also apply with regards to heat transfer to the calipers in this case?
TI also doesn't hold the heat as much as stainless. I can touch my TI exhaust minutes after exiting the track. It's rather amazing!
It's an interesting upgrade tho. I'd like to see more testing. What do stock pistons cost?
stainless shims are cheaper and have lower heat conductivity vs titanium shims.
