AutoX in wet/damp and tire choice
Old Jan 12, 2013 | 01:41 PM
AreSTG's Avatar
curious where the line is usually drawn for deciding between a "slick" (in my case A6), and a street tire (Hoosier RS3 until they die). My original thought has been if it's even just damp all over the course to run the street tire. I'm starting to think that may be flawed. Is it just for standing water where you need the siping action of a street tire, or is it happening even on a very damp track? is there more to it like how the compound reacts?
The A6's are much larger than the street tire in width, so the contact patch is exacerbated by this in addition to the tread.
thanks for the wisdom.
Old Jan 12, 2013 | 01:56 PM
Dallas J's Avatar
Veteran: Army
I only change to street tires if there is standing water. Good A6s need little heat to work compared to V710s. On the kumhos I would switch even if it was damp out cause they're aweful with no heat.
Old Jan 12, 2013 | 05:10 PM
chrisw's Avatar
any time its raining hard enough to create standing water, then it is time to change tires. How much standing water you can tolerate depends on how much heat you can get into the tire.
Old Jan 12, 2013 | 06:45 PM
Iowa999's Avatar
Also, if you're going to use your streets as your rains, next time around I would get StarSpecs, instead of R-S3s.
Old Jan 12, 2013 | 07:04 PM
VR4orceCJ's Avatar
Cool
A6s until you have standing water... I prefer the BFG R1S, but the softer compound DOT 'slick' works amazing (at least until you need the tread to sipe away the water).
Old Jan 13, 2013 | 02:34 PM
AreSTG's Avatar
awesome guys. exactly the info I was looking for.
Thanks
Old Jan 19, 2013 | 08:56 AM
FilthyEvo's Avatar
Agreed with the above!
I ran A6's at my last autocross in damp/wet conditions. I grabbed the FTD by over 2 seconds that day.
IMPORTIMAGE
Lancer Ralliart Vendor Classifieds
138
Jul 13, 2016 06:33 AM
RalliartJP
Jul 26, 2013 08:18 AM
RallySport Direct
Vendor Classifieds
May 9, 2013 12:26 PM
thejoshster
Nov 29, 2012 08:37 PM
