Road Course: Part throttle drivabilitly
I was curious what helps combat boost surge during part throttle application while on road courses?
My personal example is my RS has a hard time with turn 3(medium length left hand sweeper) at Road Atlanta, between 10a and b at Road Atlanta, or anytime I run up on a slower car mid corner. I normally keep the car in fourth and coast until I can full throttle down through the Esses. If I try and give it part throttle the car boost surges and bucks, which is not ideal.
Can tuning correct this? Lower boost level(car was at 24psi)? MAF vs Speed Density? I've seen coil on plug setups advertise that it eliminates boost surge, is there some truth to this?
I'm just trying to make the car be as smooth as possible.
Thanks
and cheers
Craig
Thanks
Craig
Thanks
and cheers
Craig
Thanks
Craig
I am assuming electronic, as I have not experienced these issues on a mbc. Usually it is an improperly setup ebcs. You need the wgdc maps set up properly, if you are on v7, wgdc by gear is your new friend
.. Also there is a possibility your wgdc 100% until xxx load needs properly configured.
Not sure. It came with the car and I haven't messed with it. I will check it out tonight. Unfortunately the car is currently out of commission with the motor being built. I'm trying to get a game plan together when building the new setup.
Keeping it in 4th, for me, is just plain faster.
I hope that all made sense lol.
My car had bad part-throttle issues, and I couldn't take it anymore. Did the conversion, and all was dandy.
