ABS "problem" Help guys! Track Car
Old Apr 25, 2013 | 08:28 AM
JARVEVO8's Avatar
Originally Posted by honda-guy
Evos with ABS doesn't have in line restrictor to control rear brake bias. It uses ABS to control rear bias. Where as evo rs doesn't have abs and has inline restrictor to control rear bias. So if your abs is not working, then your would get more rear bias then you would want.
What do you mean by this, that is going to brake more from the rear?? I have Alcon/stasis kit 6 piston on the front with the SBS race pad and on the rear the stock brembos with Performance Friction 01, if this helps on anyway...just sharing my setup to see if it influences somehow...
Thanks for your input! All are welcome.
Old Apr 25, 2013 | 02:42 PM
03whitegsr's Avatar
The ABS module is also an active brake proportioning valve. It controls line pressure front to rear based on various sensor inputs including steering angle, speed, yaw rate, etc.
Basically, the ABS system is top notch in these cars and it's kind of silly to eliminate it.
With the power turned off though, I'm not sure if it would promote or reduce rear bias. I have to imagine the OEM would make it so in the fail-safe mode, the system would reduce rear bias.
Old Apr 25, 2013 | 09:37 PM
honda-guy's Avatar
i've driven evos on track when the abs malfunction while on track. the rear will lock up much more easy than my RS without abs.
Old Apr 26, 2013 | 04:05 AM
JARVEVO8's Avatar
Thanks for your input, I hope that this thing gets solved. Freaking gremlin!
great, just great lol!
Old Apr 27, 2013 | 04:58 PM
Bueller's Avatar
Originally Posted by JARVEVO8
It was during a practice session, otherwise the marshall would not let me go out during a race! The net goes a lot further down.
Half your net is behind you in your rear window area. So my concern is that since its a "window net" i dont think its covering enough of your front window section. Get some feedback from a few credible sources. Btw, do you by any chance race in NASA ST, or SCCA T2?
Old Apr 30, 2013 | 07:11 AM
JARVEVO8's Avatar
That's because is slided back. It goes towards a lot further.
viirevox
Lancer Troubleshooting
Apr 18, 2019 01:03 PM
CottageLifer
Outlander Sport
Apr 20, 2016 06:53 AM
DarkEvo
18
Oct 12, 2015 07:54 PM
Evo_AK
16
Sep 28, 2015 12:26 PM
SilverEmperor
Aug 27, 2015 01:34 PM
