18x10's
i'm running a 285/30-18 hoosier R6 on my 18x10 +38 RPF1s and everything clears perfectly. the only thing you have to worry about is the tire rubbing on the rear trailing arm, which i why i also run a 5mm spacer in the rear to help it clear.
Over fenders being the KEY in that setup, no way 275s on a +18 are fitting under stock rear (or rolled) fenders.
The RPF1s with 285s require 17mm or greater spacer up front, -3.5* camber, and a generous roll/pull. Rears I just needs a moderate roll with custom trailing links.
Funny you start this thread, I just received my 18X10.5 NT03's in a +30 offset. No spacers needed at all, and it just barely clears everything with my 265 BFG R1S's.
Only place it rubs is at full lock on the inside frame but it's not much and will just polish off some undercoat. The rear's are close, and I have already cut the inner fender lip off so no issues there. I did smoothen out the rear trailing arm edge so nothing sharp would catch the tire under tire deflection.
With my old 18x10 +38 RPF1s in the rear on 285/30s. I also used a 5mm spacer to reduce rub on the trailing arm.
Are you running any fender mods or just a roll? 25mm spacer needed for brake clearance?
NASA Rules, the 265 BFG is as wide as a 275 Hoosier. And the 275 BFG counts as a 285 due to it being oversize, so you loose the 0.4 favorable adjuster on power to weight for 275 DOT's.
I'm not set 100% on a specific setup.
245's with extra power or jumping to 275's and adding some weight, just not sure so I plan to test. My last event at Autobahn I tried the 245's, I feel it went well but I wonder if I can do better. The 245's did melt like glue after 5 laps and it wasn't even a real hot day.
They probably are.... but I wasn't going to buy a set of 18X10's and then have to upgrade again to 18X10.5 later. I only plan to run another few events in TT2 trim. I currently have my big turbo (526hp) back on the car, and it may just stay on the car for the rest of the year. This season for me is more of a testing season and have no plans for competing in any specific series. Looking to get my feet wet in some W2W and get my comp license.
I have the Evo Dave fender kit, which I modded some to make it a little wider. I went with 25mm spacers because I was running 11" +5 and was pretty close to my shock, so I wanted a little more room. This will give me 6mm more clearance and still sit a little more sunken in than the 11s for a little more fender/bumper clearance. When I did the PSRS with the Ciro plates I started running into issues with that.
Haha, exactly what mine looked like too. With the spacers, its not bad but just fitting them flush is silly.
Roen
Jun 4, 2015 07:07 AM
ricky_g35
For Sale - Wheels / Tires
Feb 2, 2015 08:13 AM
MAX SEAT TIME
19
Jul 3, 2012 01:06 PM
ssr
35
Apr 10, 2006 01:21 PM
