Rear upper control arm issues.
Old Jul 31, 2013 | 06:53 PM
EVOizmm's Avatar
No curb or anything was hit. Was simply doing an autocross run and this happened:
Has anyone else had this issue? anything stronger out there to prevent this from happening? Do these BFG R1s's really have that much grip??
Old Jul 31, 2013 | 07:01 PM
Blue Evo 8's Avatar
Is that the stock part that broke?
Old Jul 31, 2013 | 07:12 PM
EVOizmm's Avatar
yes that is the stock control arm mount.
Edit- I take that back, maybe this isn't an OEM mount.
They almost look like the whiteline ones but obviously not yellow bushings.
Old Jul 31, 2013 | 08:26 PM
Balrok's Avatar
My stock ones have a gradual slope to the rounded part that goes through the arm, that one kinda looks flat but it may just be me. Odd ya I haven't seen that failure before. Either those bolts came loose or were loose and the vibrations fatigued the metal or you REALLY pulled hard outward. Fatigue makes more sense.
Old Aug 1, 2013 | 12:52 AM
griceiv's Avatar
those might be the works bushings. are/were both bolts tight? I've seen another car break one of those mounts because the bolts weren't tight.
Old Aug 1, 2013 | 05:56 AM
EVOizmm's Avatar
The bolts were nice and tight when I removed them.
I think you are right, I'm pretty sure they are the WORKS bushings.
There was a sweeping right hander and it was slightly bumpy. Must have been just enough shock on it to shear the mount.
Old Aug 1, 2013 | 06:06 AM
EVOizmm's Avatar
http://store.worksmotorsports.com/WR..._p/250.150.htm
Old Aug 1, 2013 | 07:09 AM
chu's Avatar
chu
Hmm, good to see this. I was thinking about replacing mine since the car now has 150k.
Old Aug 1, 2013 | 08:38 AM
flmjr's Avatar
We broke ours at Spring . We had it welded to finish the event but I replaced both sides when we got home. In the picture, the top pivot is the works bushing. The bottom pivot is the stock type and is also used in the Whiteline replacement. You can see that the bottom pivot has more meat on it.
Attached Thumbnails Rear upper control arm issues.-img_20130627_212324_058.jpg
Old Aug 1, 2013 | 08:53 AM
EVOizmm's Avatar
^ Thanks. Good to hear I'm not the only one with this issue.
alsong2002
Mitsubishi TC-SST Discussion
Jul 12, 2016 08:11 AM
tehSteve
Oct 17, 2010 02:39 PM
JordanS4
28
Oct 6, 2008 03:45 AM
Lan Evo
South Region
18
Apr 19, 2002 03:45 AM
