Know this Time Attack Evo?
It would not matter because the point of failure will be at mounting points. The force is concentrated downwards (vertically) on those point. Connecting to the cage only makes a difference if that connection allows the force to be channeled in such a way that the cage consumes that force. E.g have the front and rear scafolding on both sides go directly through the trunk of the car and connect directly to the cage as opposed to ending them and doing a horizontal connection.
Now yes it could be a very exotic very strong component whereby if the car is driven at average race speeds sub 150mph it doesn't matter but it just seems to be one of several things on this build that first glance seem really cool but under more scrutiny seem kinda odd. That being said it will be interesting to see more details on the build.
I am suprised the exhaust does not exit the side to optimize the diffuser performance. We had to side exit it because our flat bottom design caused the fuel tank to heat. We need a picture of the bottom of that car to understand what their up to...I don't inderstand why a turbo race car needs a muffler?
For airflow. They're using airflow through the diffuser to cool the radiator. They can't just place it in the middle of the car.
The pictures above show the car on a very expensive suspension testing platform. I'm willing to bet these guys knew exactly what they were doing when they designed and built the car, and the polar moment inertia was factored in to their decision.
It's all dependent on how they are managing airflow, but taking flow away from the diffuser isn't the best solution in my opinion.
Dan
I'm likely going this route on my car later this year. I figured that the extra water would be responsible for more weight than the tubes. If my internet math is correct:
Dave
- 1.25" tubes
- 10' minimum run each direction (just a guess, probably a little bit more?)
- 424 cu/in of water in the pipes
- 231 cu/in in a gallon
- water weights ~8.3 lbs per gallon
- ~15 lbs more water than stock system
Dave
yes the additional coolant is probably going to outweigh the tubing.
so say you add 25lbs. not very significant, but then again, how significant is moving the radiator to the rear to begin with?
does this also put more drag on the water pump now that its pushing water 3X the length?
I still don't see an advantage to doing this. but maybe I'm wrong.
Sometimes is packaging that causes the need for the swap. Space is pretty tight in front of the motor, and at Pikes Peak you need all the cooling you can get. Moving the radiator to the rear should allow the intercooler to get better air flow out of the core, and now I can put an even larger radiator back in the trunk area. In my car, I'm planning on having it sit under the speaker shelf, so not as far back as the car in this thread.
Dave
I thought it would be cool to put the radiator in the rear and some very large "sucker" fans that draw from the underbody of the car. I like making dual purpose modifications. but this isn't legal in most organizations.
