Sidewall flex, need answers
Old May 7, 2014 | 09:15 AM
SWOLN's Avatar
Originally Posted by griceiv
if they show inside hot, just drive faster.
Fair enough.
Dallas J's Avatar
Veteran: Army
Any noticeable difference in braking with that much camber?
Old May 7, 2014 | 10:03 AM
griceiv's Avatar
the abs can't tell a difference, still stops at 1.1g. might drive the inside temps high if the braking zones are long enough.
Old May 7, 2014 | 10:30 AM
Dallas J's Avatar
Veteran: Army
Looking at the difference of PSRS offset vs stock caster, checking 20* and 30* steering angle -3.8 to -4 deg would give roughly same camber at steering angle. This was assuming stock is 3.5* caster and PSRS gave another 1.5, and all other caster affordances were the same.
That is unless you've built a delrin offset bushing...
Old May 7, 2014 | 12:51 PM
JDavenport's Avatar
Originally Posted by MrAWD
To the OP...is that max tire size you could use for your car? 285s will be shorter to help with torque and less of sidewall, plus more thread on the road?
Fedja
NASA TT Rules, Going above a 275 DOT Slick (Hoosier, R1S, etc) gets you a power to weight penalty.
Originally Posted by SWOLN
Thees camber setting are for AX? ...or for Road Race/HPDE?
Me, NASA TT and occasional DE days, which I drive in TT trim.
Well according to my Solo accelerometer data from Road Atl in March, no. Braking at high speed into 10A saw 1.5G peak. That was at the 3.6 degree setting front, 2 or 2.1 rear.
BTW, contrary to popular beliefs, I actually run a more aggressive pad in the rear of my Evo than the front. Car is more stable, stops better and nose dives less.
Old May 7, 2014 | 01:33 PM
Balrok's Avatar
Ya just gotta be different then everyone else don't ya . But ya I agree with the others, that seems excessive, you got bed springs in there or something?.
Old May 7, 2014 | 04:47 PM
JDavenport's Avatar
No, just trying get this thing to go faster and not eat tires Springs are stiff, very stiff (800, 900)
Old May 7, 2014 | 04:53 PM
RallySport Direct's Avatar
Silver Sponsor
I run the same tires on my Evo X and I have less than a half inch of clearance and I recently noticed that the paint on my spring was starting to be rubbed away. The tire how ever didn't really show any signs of rubbing as they are minimal. Since you have more than the .5 of an inch I would say that you should have any rubbing issues since I am less than that and barely rubbing.
Hope that helps you
-Dallin
Old May 8, 2014 | 01:22 PM
SWOLN's Avatar
So do we get to see what the wheels look like on the car? :-)
Old May 8, 2014 | 08:37 PM
JDavenport's Avatar
Yep, probably in a few days. Too much work and family going on this week.
JDavenport
For Sale - Wheels / Tires
Nov 6, 2014 06:11 AM
NY Black momba
Jul 12, 2013 09:37 AM
JDavenport
May 8, 2013 10:34 AM
BURNALL_4
Dec 13, 2012 05:48 AM
HDGamer
11
Jul 6, 2011 10:32 AM
