Splitter angle at front of car
Old Sep 17, 2017 | 11:56 AM
KFC-AWD's Avatar
So I wanted to try out the APR front splitter. After installing it I didnt like the gap that seemed to be at the nose of the car and worred that it might help pull it off the car at speed on the track. I decided to put an extra 2 support bolts into the splitter and stock lip. After installing it on the car I guess those 2 extra bolts pulled the splitter up to give it a slight angle as you can see in the pics. I circled the 2 extra bolts I put on.
Is this slight angle at the nose a big issue? Should I remove the 2 bolts?
Thanks
Old Sep 17, 2017 | 01:05 PM
Yeah, not liking that upward sweep / pull of the splitter
Also, how did you attach the upper rods to the bumper? The attachment point must go to a steel member, otherwise it will pull those rods free
BTW, Im a former APR splitter user. lost one on the track 7 years ago LOL
Old Sep 17, 2017 | 01:24 PM
KFC-AWD's Avatar
I put the rods through the 2 metal support pieces that are attached on each side of the metal crash beam. So that shouldn't go anywhere.
Ya i guess I will remove those 2 bolts so the angle isn't up like that at the front.
Old Sep 17, 2017 | 01:44 PM
KFC-AWD's Avatar
I think I might try putting some washers in between the lip and splitter to let the front of the splitter be level while keeping those extra support bolts active.
Old Sep 17, 2017 | 02:18 PM
I now understand why you see guys standing on their splitters, showing the strength
On the track, at speed, there is a lot of aero load on them
Old Sep 17, 2017 | 03:49 PM
KFC-AWD's Avatar
Curious, what caused your APR splitter to come off on the track?
Old Sep 17, 2017 | 04:09 PM
It was mistakenly set-up for the street
The rods were only fastened into the bumper plastic w/a washer on the back side. At 140mph, it pulled that attachment right out of the bumper plastic & ended up dragging on the track
Anyway, that was many years ago & my bad due to limited track experience
BTW, on a side note, I am one of the few EvO owners to fail the stock 9 wing. (home track has very high aero loads)
Lessons learned the hard way!
Back on topic, maybe some of the other guys have some tips to ensure your splitter mount will survive the track
Old Sep 17, 2017 | 05:02 PM
KFC-AWD's Avatar
Oh wow, ya I've seen the evo 9 snapped wing pic awhile back on here. Luckily I have the 8 wing 😁.
Ya I'm trying to make sure that this splitter doesn't rip off, want to try to put some other support near the wheel area in front of the splash shields just in case. Did your just rip the support rods out or take the entire thing with it?
Old Sep 17, 2017 | 06:14 PM
It just pulled out the upper rod connections & some of the splitter to bumper connections. Ended up dragging on the track
Hoping some of the guys chime-in to give you their opinion
Old Sep 19, 2017 | 09:36 PM
jedibow's Avatar
That angle in the center isn't as bad as you would think, under squat the higher center will actually keep air flowing under the car and aid in aero grip on entry. A slight upward angle isn't that bad as long as it stays and doesn't get pushed up at speed...
George
Old Sep 20, 2017 | 11:47 AM
KFC-AWD's Avatar
hmm ok that's good to know. I did end up putting some washers under the lip and between the splitter on the 2 extra holes i made up front to make it more level though. It almost parallel to the ground level, just a tad upward still. With the rods attached to the support beam I was able to stand on each side of the support beams of the front lip with no problems (190 lbs) so hopefully it won't rip off.
Originally with that much tilt, I was worried that at speed though that the car would transfer the weight to the back and cause too much of an upward angle at front, but not sure how much more it would make the car tilt.
George
Old Sep 20, 2017 | 12:42 PM
killerpenguin21's Avatar
you need some form of air damn to seal off the bumper. where in south jersey are you? ive got a kognition wing, diy built alumalite splitter, and diffuser taking up space in my basement...
Old Sep 20, 2017 | 01:13 PM
kyoo's Avatar
i've also broken my evo 9 wing lol. gonna get an evo 8 cf wing soon!
Old Sep 20, 2017 | 02:12 PM
heel2toe's Avatar
^Sheesh you break that too with a hammer!? SMH
Old Sep 22, 2017 | 08:40 PM
jedibow's Avatar
Did something happened I missed Killer?
