I have some customers asking for something stiffer because they think its the flex in the housing causing some of their pad knockback and others that go through bearings from heavy track use. Like the ER car that does 24hrs on track each LuckyDog race. They're not on the stickiest of tires but heat from endurance racing does some crazy things.
I also recommend everyone tighten the axle nuts to at least 250 ft-lbs, double the OEM spec. That helps a lot, but Im also not working directly on their car to see what's going on. There's potential the thermal expansion of the axle stub reducing load, it does on lug studs.
Sorry if this sounds dumb, but If you had an extra stub shaft lying around. You could bolt down a piece of tube to simulate the hub, then toss it in an oven and see how that plays out.
I dont understand why these guys are having regular bearing failures? Maybe need to diagnose the root cause of whats causing them to fail. Maybe something in how they are running their wheel alignment or the wheel offset and install or using wheel spacers or something?
Just seems weird plenty of us here have never had issues and we have some of the most extreme evos in the world.
It's mostly a heat over time problem. Doing hours at a time can eat bearings much faster than higher power for less time. In short races bearings don't hit a "saturation" temp and if it does it's not up at that temp for very long.
One thing I've contemplated making was a bearing heat barrier (stainless or titanium shim) to put between the rotor and the hub to keep brake heat from creep into the bearing through the hub.
Right? Would be funny if it was something stupid like they were bolting the wheels on without the axles installed and rolling it around.
I've done this plenty over the years. The bearings are still self contained, just not preloaded, there's really no harm in doing it.
Yea I've heard people say pad knockback before. I'm not saying it's impossible but I've had people tell me that and they were still using factory calipers... So I'm not quick to rush to that conclusion.
But I agree on the higher torque, over torquing axle nuts is one of the must do's for older Hondas being used on track, They use bearings with preload controlled by the axle nut like the evo does and they definitely see longer bearing life from it.
While doing the Kigly & PCV modifications. I decided to see if i can improve the oil-air separation function of the valve cover, plus improve drainage and avoiding pools of oil that would get blown up again
I could go lighter on the material if i could find it but i think this will do for now. Does anyone know where to get a better material to use? These a hard to bend Thanks
Ready for testing. I'm thinking I should have tested this with a steamer. Too late to get a baseline now
I doubt anyone else would do this mod/test but just in case...You dont need this kind of modification if you've already invested in a catch can and are happy about it and the hoses/fittings etc. I hate those things
Why not fill the baffle area with some steel wool?
Vibration and air flow will cause metal to metal rubbing and put tiny metal particles in your oil. If theres a more rigid material that can provide more surface area for oil droplets to cling to then what would work IMO
I did notice bearing failure every 2 years or so too. In my case I think it was down to heat from the brakes. I had plenty of evidence around that area that I had excessive heat. I switched to Curt Brown's ceramic bearings and haven't changed anything in years.
