Hopping on corner exit
Old May 7, 2019 | 05:00 PM
kaj's Avatar
kaj
Originally Posted by Dallas J
Werd, just had to have this convo with another about aftermarket lower arms and not running them. With my rear uprights, I think the binding angle will actually break those control arms. Should probably just make an appropriate replacement for people but I'm vehemently opposed to having a threaded end for adjustment with all the load of the shocks going through it in bending.
So keep the OEMs? Much to the disappointment of my alignment guy. LOL
Old May 7, 2019 | 07:42 PM
Bee-Raddd's Avatar
lucky i kept my oems on the shelf then haha so when i get some SSB hubs from dallas i can swap back.
Also i spotted ur problem. that tracks for go karts not cars hahah.
Old May 7, 2019 | 08:20 PM
kaj's Avatar
kaj
cars with grip, anyway haha. Random trivia: My car was faster around the course than a shifter cart
Old May 8, 2019 | 08:05 PM
kyoo's Avatar
i think i experienced some hopping at my last autox event - exacerbated by the osgiken i think, vs the cusco which was pretty much locked when i touched the gas - and my super stiff rear sway bar (26mm WL on medium). the lot we run on is also really uneven, lot of elevation changes.
switching to 11k spring in the rear and pulling the rear bar back to soft, we'll see if that helps anything.
Old May 9, 2019 | 06:59 PM
V.8MR's Avatar
Edit... wrong thread
Old May 9, 2019 | 08:39 PM
kaj's Avatar
kaj
If what will help what?
Old May 9, 2019 | 08:49 PM
V.8MR's Avatar
Shoot wrong thread haha
Old May 9, 2019 | 08:54 PM
deylag's Avatar
Why run a stiffer rear sway bar with an upgraded rear differential?
Old May 9, 2019 | 09:33 PM
kaj's Avatar
kaj
stiffer than...?
Old May 9, 2019 | 10:34 PM
deylag's Avatar
Originally Posted by kaj
stiffer than...?
Stiffer than OEM.
Old May 10, 2019 | 06:43 AM
kyoo's Avatar
rear diff helps corner exit, but doesn't* change the suspension/handling of the car
Old May 10, 2019 | 07:19 AM
Ayoustin's Avatar
The diff doesn't control body roll, the swaybar does.
Old May 10, 2019 | 07:53 AM
Dallas J's Avatar
Veteran: Army
Stiffer than OEM.
Relationship to OEM rates (bar or spring) is irrelevant once you deviate far enough from original.
Old May 12, 2019 | 11:18 PM
deylag's Avatar
I agree but I had assumed that the sway bars that are produced use the OEM Sway bar diameter as a reference. One of the things I wonder is that if you run coilovers with a high enough spring rate does a sway bar even help at that point?
Old May 13, 2019 | 08:05 AM
Dallas J's Avatar
Veteran: Army
Yes because of the cross talk with the swaybars. I don't think of bars as a difference from OEM, I purely look at it as a percentage of total roll stiffness per end. In my case I run 10-15% total roll from bar up front and 30-40% in the rear.
I did try a year without a front bar and trying to make it work but it never felt right. The front always felt numb compared to the same roll rate but with a 15% from front bar and it struggled to get the back to do anything predictably even with pretty crazy rear rates. My gut says, though I haven't been able to prove it with math, some amount of front bar is needed for the rear bar to leverage off of.
As a tuning aid, the rear bar also can be used to dial in corner exit rotation with the spring use for entry/mid corner where the inside rear is light or lifted.
