-an to inches?
-an to inches?
I could SWEAR -AN = 1/16". As in a -4AN = 4/16 = 1/4", etc.
But, when I ordered -4AN PTFE fuel line, it looks to be much smaller, possibly 1/8". The OUTSIDE diameter of the hose is about 1/4". I'm guessing they are measured in OD instead of ID? If so, I have to estimate which OD to order to get 1/4" ID?
This is my goto
https://www.pegasusautoracing.com/do...ocID=TECH00096
You are right about the measurements but it references the OD of rigid tube. So -4 has the same ID as 1/4 OD tubing.
I know. That's not what I was trying to say.
-6 is a little bigger than the factory feed line, so if we are talking factory return its going to be too big. I'm not too sure how you would terminate PTFE lined hose to the factory return tube.
Not sure how else to do it. I guess since we all use AN line with AN fittings, it's not usually needed. As for a how-to, I'm gonna play with some ideas and see what pans out. I don't have a track day for a while, so may as well experiment
Until then I ordered regular stuff from O'Reilly's online as Sean mentioned.
I'm guessing on the ID since I can't find a way to know for sure. I was having to *assume* the lining "adds" 1/8" to the ID and would equal the OD.
Not sure how else to do it. I guess since we all use AN line with AN fittings, it's not usually needed.As for a how-to, I'm gonna play with some ideas and see what pans out. I don't have a track day for a while, so may as well experiment
Rather not have that happen again.
