Help with clutch line install
Old Sep 18, 2003 | 10:08 AM
tpm17's Avatar
What's up guys? I just wanted to know if there were any members who already installed the SS braidd clutchline flawlessly on their Evo and were willing to lend a helping hand? Also what type and brand of brake fluid is recommended when doing this install. I have no idea how to bleed brakes so this is why I'd like some assistance on doing this install. If some one in the Staten Island/NJ area is willing to help, I'll buy lunch! And if required I'll come to you.
Old Sep 18, 2003 | 11:23 AM
EvoJimbo's Avatar
tpm...I just go tmy line and will be doing it on the weekend. Maybe we can actually do it together b4 tehn. Ferrorahif (tommy) taught me how to do it so I have the idea down pack jsut havent physically do so. PM for my cell if u wanna meet up.
Old Sep 18, 2003 | 11:31 AM
chinalfr's Avatar
Just a note. Make sure you keep those fluid reservoir fill up. It takes me an hours to find out this. The clutch reservoir is very small.
Bleeding will be easy. Either a 2 person job or get a brake bleed tools for 1 person job.
Good luck.
Old Sep 18, 2003 | 12:18 PM
EvoJimbo's Avatar
Thanx for the tip CHinalfr!!!
Old Sep 18, 2003 | 12:26 PM
chinalfr's Avatar
No problem, bro. I learn from my mistake.
Old Sep 24, 2003 | 11:06 AM
dannylee's Avatar
Where did you guys get the SS line? I'm looking at the $59 ones from lancershop.com. Know any cheaper places?
Old Sep 24, 2003 | 11:09 AM
chinalfr's Avatar
Adam at Z1 Performance can help you. I got mine from Adam.
Old Sep 24, 2003 | 12:11 PM
tpm17's Avatar
Thanks! maybe he will install it for a small fee.
Old Sep 29, 2003 | 11:26 AM
tpm17's Avatar
Is there no one in the Northeast that would be willing to help me install this line and remove my restrictor? If you want a little money I'm more than willing to do so, I just require help from somone who really knows what they are doing, please.
Old Sep 29, 2003 | 12:42 PM
blitzbaster's Avatar
I live in san antonio. I did one last week. Kinda hard if you ask me, but I did it all alone without help/ knowhow. It tuned out alright though. Clutch feels great and grabs like a ****.
Old Sep 29, 2003 | 02:45 PM
tpm17's Avatar
Can you explain how you did it and what tools you used, and did you also remove the restrictor? I can't believe no one in the NE is able to help. I don't wanna bring it to a mechanic cuz they don't know what they are doing.
Old Sep 29, 2003 | 07:53 PM
chinalfr's Avatar
If you lived around MA area, I can help you. But you a bit far from me.
Tools need to replace the clutch cable is socket 10mm & 12mm, wrench 17mm, plier, brake bleed tool and brake fluid. Removed the battery and battery tray. Removed the clutch cable. (simplify version)
As for clutch restrictor, you need a 14mm socket, brake bleed tool and brake fluid. Loose the banjo bolt on the clutch slave cylinder. Try to reach the restrictor from the clutch slave cylinder. You might need a small screwdriver to pick out the spring and restrictor (plastic). Mount everything back and bleed the clutch.
Good luck. All instruction is on the forum. Do a search and you can find more detail.
Old Sep 29, 2003 | 08:16 PM
TRDHarrier's Avatar
what happens if you remove the clutch resistor? What is it for anyway???
Old Sep 29, 2003 | 08:21 PM
alfredob1's Avatar
Got this: http://144mph.com/clutch.htm From here: https://www.evolutionm.net/forums/sh...h+line+install
chinalfr's Avatar
Do a search on "clutch restrictor" You find the answer.
There is many speculation. For bad or good is still unknown. But for anyone familiar with DSM G2, you know the mod for removing clutch restrictor.
I removed it and found my clutch engagement is much for better. No more slipping.
