Philadelphia's Classiest Drunkards
Old Oct 19, 2010 | 05:49 AM
  #12661
AlwaysinBoost's Avatar
Originally Posted by grillpt
^ I would offer you mine, but its looking more and more like I'm going to have to run out of heat (as long as they allow me), so I can escape as soon as I can.
Ben and Kenny driving the same car? Battling it out for 4th in points, sounds scandalous!
what, we're running second. where the hell do you have to go?
Old Oct 19, 2010 | 06:01 AM
  #12662
evremonde's Avatar
If they will allow 2 drivers to run out of heat, in game. If Ben offered his car, I figure he could drive mine for the final event. That would be a fun comparison.
Originally Posted by AlwaysinBoost
^ did you contact Vince or Adam?
no i did not. After a talk with a guy at work, which included a short story about Edison ... I'm going to try to complete the job myself.
I will call rt today, it looks like rain for the rest of the week.
Old Oct 19, 2010 | 06:07 AM
  #12663
igo4bmx's Avatar
are you still dealing with the suspension issue?
did you try heat?
  #12664
chu's Avatar
chu
Kenny's quickly becoming top 10 iin post counts here.
Old Oct 19, 2010 | 06:08 AM
  #12665
grillpt's Avatar
I'm doing a ish ton of tree work this weekend. I only have the chipper for so long, and I have a lot to get done. So time isn't on my side with racing on sunday. Depending on how much we get done on saturday and how bad my yard looks (down trees all over the place), I may have to leave to get it cleaned up.
I believe his kind sleeps during the day, maybe he can answer that later.
Old Oct 19, 2010 | 06:11 AM
  #12666
evremonde's Avatar
did you try heat?
yup and I didn't have time last night, so no. Considering that i don't have a garage its going to wait a few days.
I will try the heat. A ball joint separator has also been recommended.
really? do you have proof?
Old Oct 19, 2010 | 06:13 AM
  #12667
Mr. MR's Avatar
well, he is a nurse. (does this make any sense??)
anyone interested in a co-driver? Don't think my car will be done by sunday. I'm pretty gentle on my car (according to someone here).
Ken, just come get the bar and then goto JSC for the mounts. You could run the bar and change the bushings later, one change at a time is best anyways when tweaking a car for autox. That should be easy to accomplish before the event.
Old Oct 19, 2010 | 06:22 AM
  #12668
MIke, do you know how season points are calculated this year?
Old Oct 19, 2010 | 06:25 AM
  #12669
chu's Avatar
chu
Yes. You're #10 in post counts, right underneath...gasp...Sri!
On another note, Dan informed me of rain on Sunday. Looks like weather.com is reporting occasional showers, with highs in the 60s on Sunday.
Old Oct 19, 2010 | 06:27 AM
  #12670
evremonde's Avatar
But ive already disassembled my front passenger strut. Everything is back to together, but i don't want to pay for an alignment twice... grrr
I'm going to stop whining about this btw
  #12671
turbotekray's Avatar
Good Morning Ladies!!!!!!
Im in a good mood this morning,Cliff Lee dominated the Yankees, the horse fired up on the 1st try even though it was 27 degrees, and we have our first baby doctors appointment!!! oh and hopefully the Phillies can pull of another win.
Old Oct 19, 2010 | 06:32 AM
  #12672
you should have marked your essentric bolts. Next time you get an alignment have the tech (or Pat if its RT) mark the bolts so 'in-case' you have to take something apart you can get it back together w/o needing an alignment.
you go from a pretty bone stock car on crappy tires in the beginning of the season to getting Pete's used tires to now all of a sudden taking your car apart trying to install suspension parts/bushings. Next thing you know you'll be swapping tires at events.
  #12673
Mr. MR's Avatar
I have a camber gauge, so you could just match whats on the other side and your toe should not change that much, in theory. Granted it will be not perfect but it should allow you to run. While your checking your camber, just add as much negative as you can. Then you can get the toe corrected in the near future. That with the bar should make a noticeable change in handling on course.
Marc will do it for you just ask him.... or I can bring the gauge with me or you could come get it and do it yourself.
Old Oct 19, 2010 | 06:33 AM
  #12674
Since when do nurses know about the weather? Just sayin'
I don't trust the forecast until its 3 days out anyway. Let them call for rain all they want.
Old Oct 19, 2010 | 06:38 AM
  #12675
Mr. MR's Avatar
I am not sure with the additional events that were added. The DOY and Class Point totals are listed with drops calculated, meaning they have the totals listed based on dropping the lowest points from either 2-3 events. Why not post it on the forum, you will get the correct answer there. I do not care this year because I missed the Holbert while I was in Disney with the family. That was 2 events and then I missed another event for some reason or another. So I screwed myself with points..
