Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
HELP: NW Washington Performance shops??
Old Mar 1, 2006 | 09:31 PM
  #46
timmy_g83's Avatar
I'm a fan of Axiom also...will find out soon enough how they are with tuning and their dynopacks with the up coming install of SAFCII, fuel pump and 660's.
Old Mar 1, 2006 | 09:45 PM
  #47
hanahawaiian's Avatar
GO Illtech... CODY IS DA BOMB! It brand new shop..
www.Illtechauto.com
Old Mar 2, 2006 | 04:36 PM
  #48
Airpoppoff's Avatar
www.Illtechauto.com
Old Mar 2, 2006 | 08:31 PM
  #49
Matt--- what wrong with Illtech? It brand new shop and recently open.. so it take a alot process
Old Jun 8, 2006 | 11:53 PM
  #50
WTF_LOL's Avatar
Has anybody had experience with interacing in Kent?
http://www.intecracing.com/
Old Jun 9, 2006 | 08:27 AM
  #51
voidhawk's Avatar
I've been there a couple of times, but never had any work done. They seem to focus mostly on honda/acura stuff. For what it's worth the place looked professional enough ...
Old Jun 9, 2006 | 08:34 AM
  #52
JeffR116's Avatar
Originally Posted by Airpoppoff
But they do have the only REAL AWD Dyno in the Northwest, An AWD DynoJet, and are very good at using it, And you will get an Accurate reading of HP and TQ unlike a Dynapack or a mustang dyno
Matt, please tell me you aren't serious.
Dynojet Dynos do not give the most accurate whp/wtq readings.
Mustang Dyno's apply a load, via eletro-mechanical resistance, then rwhp is calculated based on how your acceleration per unit of time of this load occurs. Mustang Dyno's also factor in vehicle weight and wind resistance.
DynoJet Dynos simply use a large drum, of known mass, as its rotating resistance...Then rwhp is calculated based on how your acceleration per unit of time of the drum occurs.
DynoJets typically read about 10% higher, and are mainly used for "bragging rights" for horsepower. This reason, coupled with the fact that they are cheaper than Mustang Dynos, is why they have become the industry standard.
It's a shame that this is the case but it's what we have to deal with.
It really doesn't matter what type of dyno you use. What's more important is that you stick with one type or one specific dyno, to measure power increases.
Old Jun 9, 2006 | 08:43 AM
  #53
voidhawk's Avatar
no dyno gives you accurate real world whp numbers - the airflow is wrong, the load is wrong, etc, etc. On top of that you can calibrate any dyno to produce any number you like. What matters is repeatability. If you can do three runs on a dyno, and they all come back the same - that's a good dyno. Then you can do meaningful before/after comparisons, or tune for a good power/torque curve shape, so you know what your new mod is doing for you. Other than that dyno numbers are just for bragging rights .
Old Jun 9, 2006 | 08:54 AM
  #54
JeffR116's Avatar
I agree that the number one reason for using a dyno is to see before/after power changes for tuning your vehicle.
I was stating that Mustang dynos are more accurate and useable. i.e. one example is being able to apply a specific resistance on their drums, which allows them to target individual loading cells at any given rpm in the ecu maps.
Old Jun 10, 2006 | 04:41 PM
  #55
brobards's Avatar
Mustang dynos do calculate HP based on weight and ari resistance, because of this you can input whatever values you want... You can make your car "weigh" 3 times as much as it does and dyno a whole lot more HP.
The dynojets can not be altered by the user so the direct comparison of car to car on a given dynojet dyno will be much more reliable than on a mustang where the user could alter some inputs to make one car appear more powerful.
The new dynoject 224xlc has the eddy current loading capability so you can now use dynojets to tune part throttle and drivability.
Old Jun 11, 2006 | 01:20 AM
  #56
Reaction360's Avatar
a little birdy told me there will be an awd dynojet in tacoma by the end of june.
Old Jun 11, 2006 | 04:22 AM
  #57
laggin3's Avatar
orly? Do tell.
Old Jun 11, 2006 | 07:35 AM
  #58
raiceboi697's Avatar
im intrested as well please keep everone posted
Old Jun 11, 2006 | 11:54 AM
  #59
will let you guys know. i think he wants to have an awd suby evo dyno day as soon as its ready.
Old Jun 11, 2006 | 04:23 PM
  #60
boostedwrx's Avatar
Originally Posted by jj_008
You figure w/ a name like "Xtreme Auto Salon" would be enough for most EVO owners to stay away .
Is that the place by Vinces and Shucks across from Seatac mall (the Commons now, whatever?) I laugh every time I drive by if it is...
