Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Hallman MBC Question
Old Oct 21, 2006 | 03:22 PM
js06evoix's Avatar
Alright, I did the research, and I finally installed the MBC.
Things work great, but for one thing, and I'm not sure if its normal.
I have it set up pretty much to boost right to 1.5 bar (approx 21 psi) @ WOT. However, under partial throttle load it will boost more than that, like 22 or so. Is this normal?
Old Oct 21, 2006 | 03:23 PM
fromWRXtoEVO's Avatar
That is somehow normal. You are experiencing boost spike.
Carlos
Old Oct 21, 2006 | 05:59 PM
uglyevo's Avatar
**** boost controllers, just pull the wastegate line
Old Oct 21, 2006 | 11:54 PM
js06evoix's Avatar
lol.. I'd like to keep my motor for a while, but thanks man.
Old Oct 22, 2006 | 02:28 AM
ashumo's Avatar
Originally Posted by js06evoix
....I have it set up pretty much to boost right to 1.5 bar (approx 21 psi) @ WOT. However, under partial throttle load it will boost more than that, like 22 or so....
Well 1.5 bar is 21.75 psi. Hitting 22 is only .25 more.
Old Oct 22, 2006 | 08:55 AM
js06evoix's Avatar
Yeah, the conversion I calculated by a table I found was PSI * .069 = Bar. I was just told that 21 psi is really the max you should run the stock ecu at. I don't want to hurt the car before its tuned. I need to get A/F measured so I can make sure its not running lean or anything either.
jagarcia89
Oct 11, 2014 06:52 AM
urslo4n8
Apr 20, 2008 10:14 AM
GeoffM
Feb 9, 2007 09:09 PM
ev08buoy
Sep 4, 2005 08:01 PM
TonyG
Apr 10, 2004 07:24 PM
