401whp E85 VIII stock turbo
Put the EVO on the dyno down at Torque Freaks today and made some good #.
Thanks TF for the dyno time.
Quick list of mods.
-'04 SSL EVO IIIV Stock trubo and hot side
-HKS 272's
-ETS IC and piping with ETS intake pipe
-PTE 780's
-255hp
-E85 fuel
-spike 26psi hold 22psi to redline.
-Flash tuning done buy me.
27psi spike holding 22psi out the top.
26PSI spike holding 22psi out the top.
My Log from the 401whp. As you can see I am using all the 780's but its just enough fuel so I am happy.
Quick list of mods.
-HKS 272's
-PTE 780's
-255hp
-E85 fuel
I would say yes at the moment. I had them around the shop so thay were kida free. You could almost say thay are Perfect for a stock turbo VIII. Would be to small for a IX for sure.
Eathonal does not seem near as crosave as Methonal. Most of our factory lines are coated. I would more more woried about the rubber geting hard and cracking but I bet it would take a few years for that to happen if it is even a problem.
I like to find things out 1st hand so I will let you guys know if I run into any Problems.
I want to test drive that one, I bet it is a blast to rip around!
