7mm~10mm spacers
Go here:
www.wheeladapter.com
Very good service and turnaround. The spacers are made to align with both your hub and wheel. You can order custom sizes as well. They are a little bit pricey but the product is well worth it.
As for the wheel studs I bought the kyo 52 mm wheel studs from RRE. Also very quick turnaround and shipping.
Go here:
For those who went through wheeladapters.com
Does anyone know the Center bore of our hubs?, also he said that I need to measure something on my aftermarket wheels maybe the size of the hub on the inside of the wheel so that he can make a lip or something so it holds snug? ideas? Kyle R?
Call your wheel manufacture for the center bore, or see if you can't find it on a spec sheet somewhere. He should have the hub size for the evo, if not see if someone can measure it with a micrometer. Mine fit perfect with the measurements he had for the evo hubs. I won't be near my car for a while and I think I gave the measurements over the phone so don't have them handy. Good luck!
Isn't it a bad idea to put spacers on any car? The wheel offset keeps a proper load on the wheelbearings, where a spacer and a bad wheel offset is going to destroy your wheel bearings.
