Need ecu flash help bad
On this topic I should add that really and truly if you are going to do a fair amount of mods to your car you should buy a wideband a/f gauge of some sort. This is the 3rd or 4th car in the last week or so in this area where the person is going "i think the car is too lean or too rich"....having the gauge at least will allow you to "eyeball" and see where the car really is. Plus its one basic way to verify a tune that someone has given you (or the one you are doing yourself).
You are not running lean with those mods.
I can flash you with John's flash, I can pass the money off to him. PM him for price. I run this same flash, see my sig for 1/4 time. John pulled off a 12.2 @ 112 on pump gas with it also, but I'm heavy
It was great, I definitely feel an increase in power from the tune as opposed to when I got dynoflashed, I felt no increase whatsoever. Dynoflash had me running really rich, that's been fixed. Definitely worth the money in my opinion.
I think you can't really go wrong with a lot of choices. Herb@Axiom, JohnBradley, Lucas, Jestr, etc, I've heard good things about. I think it would be better to keep it local, though. Just my opinion, though
Herb Jackson is a well known EVO tuner in the NW. He has a established list of clients that he has worked with and none of them really complained. So, he is also an EVO owner himself. He is also very knowledgeable about the EVO. You can go talk to him if you want to, just go to Axiom, ask Kyle to call Herb and set up an appt date, He usually is available on Saturdays...go talk to him and see
