Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Bad Bad Bad problems
Old Jul 17, 2003 | 11:14 AM
jaxjoker's Avatar
sorry for another thread on this... but ok... so i installed my intake. Did everything right and everything pluged the ECU and **** back into mass airflow sensor or whatever... Car runs like ****... idle low rpms Dies alll the time i figure mabye i just have to put some miles on it to recalabrate or something... so i put 40... stilll runs like ****... i unplug the ECU from mass airflow sensor... cars runs sooooooooooooooooooooooooooooo nice... runs like a Dream... idles a LITTLE high but.. so i take it out for a drive... when i push the Brake pedal or Clutch Pedal they Clank, Clunk, knock, i dont know the word to describe it but they dont feel right its like when i get them half way pushed down they start knocking and its really worrying me..... any ideaZ??? sorry i cant describe more its a little hard on the internet..
Thanx,
Jason
Old Jul 17, 2003 | 11:29 AM
mobius97's Avatar
I had that happen once to my eclipse...when I pushed in the clutch (still parked0 I heard a bunch of noise. A kind of clunking..check your pullies and see if there is anything lodged in there bumping around. My pulley actually broke into peices. Did you disco the battery and let it sit? DO NOT run your car with the MAS unplugged.
Old Jul 17, 2003 | 11:31 AM
Guru_Del's Avatar
what intake is this?
Old Jul 17, 2003 | 11:36 AM
think's Avatar
Old Jul 17, 2003 | 12:44 PM
jaxjoker's Avatar
Can someone Explaine Exactally what the MAS does??? and why it cant be unpluged?? heh probly sounds like a dumb question but i dont know the answer.
Old Jul 17, 2003 | 12:46 PM
boostedwrx's Avatar
sounds like you may have damaged the MAS if it runs better when its not plugged in =(
The car wont run right with the MAS unplugged, but if it runs better than when it WAS plugged in, its definately the MAS
Old Jul 17, 2003 | 12:47 PM
mobius97's Avatar
hey boostedWRX did you get my PM?
Old Jul 17, 2003 | 12:54 PM
psionic98's Avatar
MAS reads the incoming air and tells the ecu how much fuel to dump into that air to combust... you need it or you will run lean and waste a ton of gas and the exhaust would probably be smelly! maybe you put the MAS in backwards?
Old Jul 17, 2003 | 12:55 PM
uranium9v's Avatar
I've driven around with it unplugged...it just eats fuel like crazy and puts the ECU into Limp mode.
ohcanada_00
Northwest Region
11
Mar 19, 2004 07:48 PM
silverEVO8
Southeast Region
14
Nov 29, 2003 10:38 PM
MistaJimmy
Aug 24, 2002 09:12 AM
