info on meth injection kits
I am at a high elavation and the AEM is a great kit for the cost. this kit comes with a warnig and nock lite plus a warning light just incause the pump or the tank is empty. Alot went into this kit. Plus I like it is a full gallon tank. and the pump is a high pressure. As well as the nozzels to choose from. so you can fine tune to you on mods. I picked up 40hrs. at the wheels and the only reason I had to stop there is that I did not have head studs yet. So I will pick up more after I install those.
i really want a bigger hour gain, im looking to be in the 60hr range, any suggestions?
Of course, you can go by dog-hours which allow for a factor of about 7:1, if you can handle that kind of powa'!
It will be close to that 60 horse gain after my head studs are in. the only thing is that I could go for more but I oppeted to stay at 24lbs in stead of going to 26 or 27lbs. so you can get it you just need to be safe. Head studs will save you some heart ackes.
I have the Labonte and love it. As for where to get in WA, someone already mentioned checking local race/tuner shops in your area and they can get it for you. I keep two 5 gallon drums in my garage that I get from my tuner when I need more.
TTP, can you PM me the info on how to setup my Zeitronix as a secondary safeguard to the IFS -10 using AFR and EGT safeguards? I have the full Zeitronix setup.
Thanks
Thanks
Thanks
Thanks
So yeah, where in seattle are you guys getting real chemical grade meth?
