Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
ETS PT61 Turbo Kit & New Dyno Numbers
Old May 11, 2008 | 03:09 PM
Kevindanger's Avatar
I forgot to say that has a blow through MAF. Once again it is Stock block and head. Stock intake mani and Stock TB. Everything else I pretty much changed. Aaron and Lucas tuned it. So big thanx to them. It is ETS super valve kit with the unequal lenght ex mani. So it doesn't have the s cover. The spool isn't too bad. Most people say it is like a sling shot full spool about 4500 plus of minus a few 100 depending how your setup is I don't have a current pic of my engine. You can find some pic on ETS web site.
Old May 11, 2008 | 04:54 PM
03evo4g63's Avatar
Are you still using stock flashed ECU with blow through MAF, or are you using a piggyback such as UTEC to tune it?
Old May 11, 2008 | 04:55 PM
Stock ECU
Old May 11, 2008 | 05:11 PM
mitsuboost30's Avatar
Yes Nick (xaioni) was wanting to see ur setup.. the blue car on ets's site is his car!
clean and crispy
I would like to see some pics of your setup aswell...
I am going to go with this kit also in the near future!
once again nice numbers
Old May 11, 2008 | 05:18 PM
SickSilverNLow's Avatar
what cams are you using? Pics of the engine bay please .
Old May 11, 2008 | 05:23 PM
JordanS4's Avatar
those numbers are low for that setup.
Old May 11, 2008 | 10:17 PM
JohnBradley's Avatar
AWESOME KEVIN!!!!
We were out with the quads this weekend in the land of no signal. THAT rocks..amazing how much power you can find with a little AFR work
Old May 11, 2008 | 11:12 PM
codgi's Avatar
Nice to see the real numbers for this setup .
Old May 11, 2008 | 11:19 PM
stock cams. Actully the car is being a little b!tch again. I think it wasn't warm enought.
There is and old pic from ETS site. It is a little different now
Not for stock cams
Old May 11, 2008 | 11:20 PM
What did you actually change aaron??
Old May 11, 2008 | 11:25 PM
555R's Avatar
do you have a better pic of the dyno sheet?
Old May 11, 2008 | 11:35 PM
Because of how the MAFT works with the stock ECU and how it makes the load change, I took out fuel till I got consistent 11.0-11.2 AFR and added 2* of timing till I got knock and backed it off. I think the car ended up with 15* out the top compared to where it was before at 9-10*. That was all with the boost set at 23 or whatever it came in at as well. It has a knocklight on it so I am not worried about the extra boost if you didnt see it blink. Can't wait to see what it can do on pump gas.
Old May 12, 2008 | 12:10 AM
on pump gas?? it had 92 oct in it when playing with it
I'll try to get a better pic
