Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Not running right..need help!!!
Old May 31, 2008 | 12:17 AM
EvO03's Avatar
Hey guys! I just got a 3.5inch core intercooler with licp/uicp and an intake.. My car studders a whole lot and doesn't idle right. It also shuts down when I'm on the accelerator and just let off. It doesn't run right at all!!! I need some help... What would cause this to happen?? Does anyone know what might this problem be? Please Help!!!
Old May 31, 2008 | 12:27 AM
unlimited02's Avatar
it sounds like ur have a leak... what kind of clamps do u have... T bolt or regular ones..?
Old May 31, 2008 | 12:28 AM
TurboTim06's Avatar
sounds like possibly a maf problem..what kind of intake?
EvO03's Avatar
I actually have the t bolts on there... Looked for leaks, but found nothing....
Old May 31, 2008 | 12:30 AM
EvO03's Avatar
I can't remember off the top of my head... It's at a buddies house right now... He ordered the intake for me... What kind of problem with the MAF are you talking about?
Old May 31, 2008 | 12:32 AM
hmmmm
i dont know then...
Old May 31, 2008 | 12:35 AM
TurboTim06's Avatar
possibly dirty or damaged? that would cause a bad idle and stalling...usually it would trip a code tho..theres no engine light on?
Old May 31, 2008 | 12:36 AM
EvO03's Avatar
Nup... Throwing no kind of code.. however my SRS light did come on....
Old May 31, 2008 | 12:56 AM
hanahawaiian's Avatar
put right BOV in postion right flow air direction? and MAF sensor plug in?
i can help you ya if u need.
Missed any Couple tight.... I suggest best is T-bolt Clamps instead cheapo screw clamps...
Old May 31, 2008 | 10:26 AM
xturdfergusonx's Avatar
I agree, check the bov and make sure you plugged the maf in. Simple mistake......
Old May 31, 2008 | 10:45 AM
03 Evo V///'s Avatar
BOV recirced? mine is not but Lucas tuned as best as he could to comp with rough idle. If you did recirc then i would agree with backwards bov and maf not clicked in all the way.
Old May 31, 2008 | 11:36 AM
bamboo_08's Avatar
where are you at in seattle? i could swing by and look at it if you want.
Old Jun 1, 2008 | 09:10 AM
EvoInvidia's Avatar
his bov is probably on wrong lol.
Old Jun 2, 2008 | 11:59 PM
EvO03's Avatar
I put the stock BOV back on... still the same.. I had the GFB all the way recirc...but I didn't check to see if the MAF sensor plug was in all the way.... I can use all the help I can get right now... Thanks!!!
Old Jun 3, 2008 | 12:00 AM
EvO03's Avatar
I work in Bellevue, live in Mill Creek... Lemme know if there is a place we can meet.... I'll drive out to ya... That would be cool if you could help!!!
