ETS I Need Help
ETS I Need Help
I have a GT35R and a Tial 42 mm .9 bar wastegate, the wastegate will not close. I have tried every schematic I could find for a MBC, but it still stays open and I have no boost at all. Thanks anyone who can help!
Well, the bladder was fine, the v-band is loose though, its closed all the way but still rotates easily. I will try to hook it up to the stock BCS since I am able to reflash again.
Is the fire ring installed? The ring will be installed on the manifold side of the wastegate.
See this diagram - I know it's a 38mm but it still needs the valve seat.
http://www.tialmedia.com/documents/w3_tial_wg_assem.pdf
