Scott... Now with E85!!!
15psi. It will spike 27 and then drop like it already has a restrictor in it. I havent played with a high boost stock airbox car before. The last one I had was mine but I had the lid cut so it was actually pretty free flowing. I almost I think the MBC might be the issue but not sure yet. Hopefully that is what is it since thats easier to fix than make a stock airbox (needs to be there because of the class regs) work better.
I tool a look at the other turbo I have here and I guess I can see how that if the valve won't stay close while boosting, it would dump the pressure like we're seeing.
Question is, how to fix it and still be "stock".
Hmmm.....
Scott
fp has a stock high pressure WGA im sure you can put that on and still be in the class. cuz I dont see why not if you can put a MBC on cuz they both have the same effect.
http://store.forcedperformance.net/m...Lancer-TurboHW
thats what I would do plus one will ever know and also your WGA is bad so you had to get a replacement
Seriously, I'm not even going to come close to bending the rules on this or any other thing. I'm going to have enough scrutiny as it is, stuffing an EVO into this class.
Scott
what events are you doing?
(working on leaning it out to the right AFRs and then more timing)
