Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Got bored today... made a cam sensor cover...
Old Apr 12, 2009 | 03:03 PM
Fast_Freddie's Avatar
Veteran: Navy
Had a piece of metal laying around from the back of my dryer so I turned it into a cam sensor cover... on to the pics!
Attached Thumbnails Got bored today... made a cam sensor cover...-cam-cover.jpg   Got bored today... made a cam sensor cover...-cam-cover2.jpg   Got bored today... made a cam sensor cover...-cam-cover3.jpg
Old Apr 12, 2009 | 03:07 PM
evo unknown's Avatar
Nicely done, productive day!
Old Apr 12, 2009 | 03:09 PM
Veteran: Navy
Yeah... took me about 1.5 hours... it was free, however it still cost me about $50 cause I burnt a hole through my Northface Fleece
Old Apr 12, 2009 | 04:35 PM
importjake00's Avatar
^^^^ dumb ***
Old Apr 12, 2009 | 04:57 PM
drb's Avatar
drb
Looks good
Old Apr 12, 2009 | 04:58 PM
JordanS4's Avatar
why? you have a stock manifold.
Old Apr 12, 2009 | 05:39 PM
hanahawaiian's Avatar
Look good bro... why u wear Northface lol...
Old Apr 12, 2009 | 05:52 PM
evosam726's Avatar
looks good... u can almost go pro doing stuff like that lol
Old Apr 12, 2009 | 09:06 PM
Veteran: Navy
Originally Posted by importjake00
^^^^ dumb ***
Thanks queer bait!
Why not?
I wasn't planning on making the cover... just saw a piece of metal laying around and dived into it with no plan...I did all this with a dremel and a drill
Old Apr 12, 2009 | 09:15 PM
haze1995's Avatar
nothing like adding weight (although not much, but you did) to your car?
Old Apr 12, 2009 | 09:23 PM
JordanS4's Avatar
Why not? No reason, except that it's not necessary. If it was, Mitsu engineers would have done something about it.
Old Apr 12, 2009 | 09:48 PM
Veteran: Navy
I have read numerous threads about failed cam sensors due to heat... the stock maifold is cast it actually produces a lot of heat... Lots of things that we do aren't necessary, and I have done a lot of stuff to my car that isn't necessary, but I do it because its something I wanna do... And about mitsubishi engineers... they do a really great job with a lot of things, some things can be approved upon. For example... I had a really weird set of stock cams in my EVO that would run about 10-15 degrees less timing than every other set besides Kaymin, as he had the same exact problem...look at how rich the stock AFR map is from the factory, that seriously can be improved upon. If everything was perfect from the get go, there would be no use for the aftermarket industry...
Yeah that 1.5 oz is really gonna hamper things... that is like putting a CD in the player... Considering I have an SSL, I don't think I am worried about weight savings
Old Apr 12, 2009 | 10:25 PM
drb's Avatar
drb
I doubt that the additional weight will be an issue. If so he could always carry less change in his pocket!
Old Apr 12, 2009 | 10:36 PM
wshihdnevo's Avatar
I seriously need to get over to Jareds and make one of these. Looks good Freddie.
Old Apr 12, 2009 | 11:36 PM
Billy@EnglishRacing's Avatar
Are you saying that the evo has no faults? There were alot of things on the evo that Mitsu engineers over looked.
All he has to do is not chew gum while driving.
