alignment help!!
alignment help!!
hey guys i was wondering wats the specs for the street aggresive alignment? im getting my done tmr and i havent found any specs on it.. anything will help thanks..
This isn't the exact answer you were looking for, but I searched the tire, wheel and suspension section for "alignment spec" and came up with this;
https://www.evolutionm.net/forums/se...rchid=10816578
The search function isn't quite what it used to be, but some of it is very applicable.
edit* here's the factory specs
https://www.evolutionm.net/forums/ev...alignment.html
Only toe and camber are adjustable on the Evo (OEM). You want zero toe everywhere to save your tires. The front only has two camber settings (slightly neg, or more neg), most people go with the more negative setting. Rear camber is up to you, depends on how well your front sticks (more negative rear camber = better rear stick = more understeer/less oversteer).
whitersevo
Mar 2, 2014 09:16 PM
jd888jd
May 12, 2011 03:01 PM
shinobee1
May 28, 2008 08:48 PM
