4g64 2.4 Built Short Block
Old Aug 1, 2009 | 11:59 PM
fuzzydoodle's Avatar
Hey guys, I have a built short block here I bought built from a shop in Co.
I had bought it under the impression it would fit my 2g, being out of a Spyder, but it was a later year Spyder.
Just so happened to be the Spyder that Evo guys use for their 2.4 builds, this is an already built motor, ready to bolt on your head and drop it in.
Here are some specs / pics:
JE Pistons 8.5:1
Eagle Rods
ACL Bearings
ARP Main Studs
ARP Rod Bolts
BRAND NEW 4g64 Block
BRAND NEW 4g64 Crank
BRAND NEW Oil Pump
Balance Shafts Eliminated...
BRAND NEW Main Girdle
BRAND NEW F R Main Seals
BRAND NEW Water Pump
Also is drilled/tapped with oil squirters.
Old Aug 2, 2009 | 12:41 PM
kaymin's Avatar
How much!?!?!
Old Aug 2, 2009 | 06:22 PM
Billy@EnglishRacing's Avatar
Who built it?
Old Aug 6, 2009 | 10:41 PM
R/TErnie's Avatar
Does it have a stub shaft? or an AMS style shaft?
Old Aug 13, 2009 | 01:32 PM
I got ahold of the guy I got it from, to find where it was built because I forgot when he told me.
It is from Street Concepts in Colorado.
Built with a gap to hold the equivalent of around 600 hp. Maybe a little less, with some blowby.
The guy told me it was for my year DSM, and it was from a Spyder, since thats the 2.4 block I needed.
It turns out it was from the later year, which I can't use ONLY because the transmissions have a different bellhousing pattern, which like I said, happens to be the same as an Evo.
Which is why any evo with a 2.4 has this engine, much like DSM's with 2.4's have either a 4g64 (7bolt) out of a 95-99 Eclipse Spyder, or a g4cs if I remember right (6 bolt) out of a Hyundai.
So if you're looking for a nice street monster, with some track use, this is it.
2.4's are the way to go, as opposed to 2.3, its less stress on you're cylinder walls/rings, and if you're going for a big turbo, its the only way to go, way less lag.
Old Aug 13, 2009 | 03:03 PM
importjake00's Avatar
If you still have this for sale in a couple months, it will most likely be bought if the build stays on the same path.
Old Aug 13, 2009 | 07:10 PM
Evo_TK's Avatar
How much is it?
Old Jun 28, 2010 | 08:36 AM
yahu's Avatar
JE Pistons 8.5:1
Eagle Rods
ACL Bearings
ARP Main Studs
ARP Rod Bolts
BRAND NEW Oil Pump
Let's do eet!!!
Old Jun 28, 2010 | 07:06 PM
Rxracer's Avatar
i see mazda 13b N/A sereis 5 intake manifold in the back......
dsm nexus
27
Sep 3, 2016 02:05 PM
dsm nexus
For Sale - Cars For Sale
20
Jul 23, 2015 06:22 AM
dsm nexus
17
Sep 7, 2014 09:46 PM
AJXX323
09+ Ralliart Show and Shine
13
Aug 29, 2014 05:25 AM
