Race Gas in/near Seattle!
Here you go Yahu... http://www.dsm-ezine.com/evoVIII_adc_switch.html
so I can use the fog/ACD switch to go back and forth? Its just a tephra patch that Aaron can flash for me when I go get tuned when I get cammed right?
kinda like the knock light and valet mode?
Adding race gas to a pump tune should be done in small amounts. Like 2-3 gallons at a time. Adding more than that and the other effects of negatively effecting your AFR and slower burn rate actually will result in less power (or atleast no extra). Unless that is you are tuned on the ragged edge with higher an AFR that is above norm. With that said I usually throw in a couple gal. if I hit the track. Used to keep it around when I rode my dirtbike alot but not so much anymore...waiting for fking corn to come closer...swear I'm gonna be 40 by the time that **** gets here.
Just got back from Thasher's. 101 unleaded is $8.50 a gal. and 110 leaded is $10.50 a gal. smfh! You're not allowed to pump 110 leaded in to your car you need to have a gas can if you want 110oct. These prices are crazy.
I would if it was more locally available...the closest station that i kno is the one that i jus recently discovered thanks to Mikey (BLKCarbonEVO)...the shell station off of I5 exit 206...i plan on tuning for E85 this summer also tho
