Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Factory brake cooling ducts/guides?
Old Sep 28, 2009 | 04:32 PM
GTisRule's Avatar
Yeah, sounds like the same crap. So I had both front rotors turned on a lathe, and there appears to be some difference in metals now on both front rotors. I'm running Ferodo DS3000's, so I figure I'm going got swap in these rotors on track days, and not have multiple compounds ever come into contact with the rotors and hopefully fix another braking issue.
Old Sep 28, 2009 | 10:59 PM
codgi's Avatar
Originally Posted by tyre11c0rp
I read up in the Motorsports forum: not a lot of positive reviews on these.
I instead went with the Forged Performance ducting kit, and mated them to Ferodo DS2500s all around. Even with the ducting, I was getting a bit of fade, so I switched to DTC60s in the front: problem solved. I'm running ~320whp, and 255/40 AD08s.
bottom line, I don't think you'll see significant advantage from going with the guides, at HPDE.
How was the install for that kit? I haven't seen much pictures of it...but from the description I've seen on some sites it seems similiar to the AMS one.
Old Sep 29, 2009 | 08:45 AM
tyre11c0rp's Avatar
install was not bad. Since it's also my DD: I had to replace the ducting after the end of the first season, as it got pretty torn up. Not a big deal, about $60.
Old Sep 29, 2009 | 08:55 AM
TxEvo8's Avatar
In my experience the 2500s will not hold up to heavy track use, you might want to switch to track pads.
Old Sep 29, 2009 | 10:29 AM
tyre11c0rp's Avatar
Replaced with the more aggressive DTC60 compounds...
Yup I'm running DTC-60, GTI is running 3000s.
Old Sep 29, 2009 | 12:06 PM
aeroweenie's Avatar
Matches my experience. And overheated DS2500's do tend to transfer unevenly causing big time shuddering. I switched to Pagid RS29, but these did not clean up the rotors enough so I got new 2-piece rotors. Problem $olved.
Old Sep 29, 2009 | 03:55 PM
jid2's Avatar
DS3000's are notorious for pad transfer and uneven deposits..... boo.
I'd run Hawk DTC-60 or Raybestos ST43's for track pads. I love me some ST43's.... After 4 track days they still look nearly new in terms of wear.
Old Sep 30, 2009 | 12:23 PM
GTisRule's Avatar
That's what's got me so burned, these are on BRAND NEW blanks. How do you prevent the pad transfer? I followed the brake in procedure every time I swap pads for track days.
Old Sep 30, 2009 | 02:09 PM
divine_evo's Avatar
thinking about going to the oct 10 track day in oregon with GTisRule but not so sure after hearing the news on the ferodo 2500s. that is what i'm running. I need to make sure i can get back safely to seattle.
Old Sep 30, 2009 | 02:17 PM
GTisRule's Avatar
You're not changing pad compounds though, I think that's where my problem came from.
Old Oct 1, 2009 | 08:06 AM
jid2's Avatar
Pad transfer seems to be a characteristic of certain pads when over heated, some are worse than others. The Ferodo DS3000's seem to be a bad one.
I never had problems with my DS2500's, but I always ran ducting with them and mostly on street tires.
Old Oct 1, 2009 | 08:09 AM
Smike's Avatar
I wrote a massive thread on pads/ducts/rotors/etc in the Wheel/Tire Forum. DS2500s are not track pads, MOT of 1000F is pretty easy to run up to on the heavy Evo.
Old Oct 1, 2009 | 08:55 AM
tyre11c0rp's Avatar
+1. I went from OEM --> HPS+ --> DS2500s ---> DTC60 front / DS2500 rear.
I'm not running high horsepower, or R compounds, either... and I have the Forged ducting kit to keep things cool.
I thought I could get away with the DS2500s as a street/HPDE compromise (especially with the ducting kit), but no dice.
Finally happy with my setup, although it took 4 iterations to get there. No pad transfer, no fade, just strong reliable braking.
