Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
MBC install
Old Dec 10, 2009 | 04:07 PM
cush87's Avatar
I used method #1 for a while, and switched it over to method #2 after reading some threads on the subject. Method #2 kept the boost more stable then method #1 did for me.
Old Dec 10, 2009 | 04:16 PM
dbsears's Avatar
Originally Posted by McDougal
Cool, thanks.
What does it cost to convert to a GM solenoid?
It can cost anywhere from about $50 to $100. You can either buy a GM 3port for about ~$50 and splice the two wires into your stock BCS harness or purchase a full P&P setup from Tactrix for ~$100.
There is also word floating around the Ecuflash section that if you have an EGR blockoff and remove that unwanted junk one of those sensors is an OEM 3port solenoid that can be utilized for boost control.
Old Dec 10, 2009 | 09:31 PM
McDougal's Avatar
Thanks for the info, I appreciate it.
Old Dec 11, 2009 | 12:59 AM
F0RSAKEN's Avatar
+1 for method 2. I have my Blitz SBC i-D Spec R run essentially that way, boost source from turbo, output to wastegate.
chaotichoax
Jan 30, 2010 11:15 PM
chaotichoax
Jan 30, 2010 10:58 PM
chaotichoax
Jan 30, 2010 09:45 PM
chaotichoax
Jan 30, 2010 06:46 PM
Joe250
12
May 4, 2009 07:03 AM
