Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
ecuscan Q
Old Oct 11, 2010 | 03:53 AM
F0RSAKEN's Avatar
ecuscan Q
I know a few of you do some logging, got a quick question for ya....
EcuScan is logging, at times, over 100% injector duty cycle, which I know means the injectors are too small (or possibly, from what I've read, a fuel pump deficiency), but I'm on stock turbo, and it was registering that duty cycle at only 17-20lbs of boost. Ambient was ~55-60 degrees, full WOT run to 8k in 3rd gear.
Is it registering correctly, and I need to put in my larger injectors, or is it registering incorrectly, and I need to change its bit address or something else?
Note, my wb02 was not plugged into my laptop, and I was looking at the road, so I'm not sure what my AFR's were.
Old Oct 11, 2010 | 04:10 AM
Mellon Racing's Avatar
don't get too hung up on the boost number, a modified car can make more power at low boost than a stock car at high boost, thus requiring more fuel. Also if your AFR is grossly too rich the demand for fuel may exceed the stock pump/injectors at low boost.
I would get the AFR to ideal and see if the IDC comes down first.
Old Oct 11, 2010 | 07:25 AM
dbsears's Avatar
IDC does not show up correctly in Evoscan because of the scaling it uses. It reads about 10% high or so if I recall.
Old Oct 11, 2010 | 01:48 PM
F0RSAKEN's Avatar
Ok cool deal. I found my serial -> USB cable so I can start logging AFR, I'll see what it's at.
Question 2: what is Throttle Position supposed to register at idle? I get a constant 13.xxx%.
Old Oct 11, 2010 | 02:41 PM
JohnBradley's Avatar
13.333% at idle is correct.
I also finally figured out the hot start thing. Be so kind to send me a copy of your ROM and I will make the needed changes to get it stock.
Aaron
Old Oct 11, 2010 | 03:26 PM
Ryan.Kauz's Avatar
^ all this customer service!!!!!
Isnt it more fun to let the customers try for a few months before giving them the info? he has a spare car to use
Old Oct 11, 2010 | 06:54 PM
F0RSAKEN's Avatar
Aaron
I'll pull the map on the RR as soon as I put it back together, and send it to ya.
Currently I'm trying to get the hang of tuning on my WW, I flashed it to 88591715 last night. The only trouble I am having right now is the cold start problem. I'm going to go through Aplaudd's thread later tonight, see if I can't cure it lol.
EVOMIZ
Dec 8, 2019 05:58 PM
EVOMIZ
Nov 27, 2011 05:33 PM
PlanoEvo
Dec 5, 2009 06:05 PM
MR_EVO21
Jun 13, 2007 09:45 AM
kapolani
Feb 3, 2007 06:21 AM
