Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
30k Service location and questions
Old Mar 4, 2011 | 02:48 PM
llDemonll's Avatar
So this is what I've gathered for what I think the places will do for 30k service
oil change
rear diff fluid change
acd fluid change
tranny fluid change
transfer case fluid change
sepentine belt change
timing belt change
clutch fluid change
brake fluid change
general coolant flush
spark plug change (?)
tire rotation
general inspection
I'm thinking of taking and paying for this for the 30k, since car is new to me and it'd be nice to have everything done right the first time
Main question is on advice as to where to get this done? should i just go to the dealership (didnt buy the car from there) or is there a better place (i.e. english racing, cobb, etc) to get it done?
I'm looking at having them put shifter bushings in at the same time, so advice on these as well. i hear they're one of the first things you should do to the car
Old Mar 4, 2011 | 03:13 PM
drocksmash's Avatar
I was in the same boat as you... But ended up getting help from members to do all that except the ACD/clutch and belts.
Is the ACD even required @ 30k?
Yeah it is nice to have it done right the first time, but if you can do it right the first time, you will do it right everytime.
Offer to pay someone a little and buy the fluids then spend some time on your girl!
Old Mar 4, 2011 | 03:17 PM
llDemonll's Avatar
The only thing I'm not comfortable with is the timing belt and serpentine belt, those were the main reason I would be taking it to a shop and definitely something i'd be willing to pay someone to have done
fluids and all that i have a garage, jackstands, and friends who can help (may even have a 4-point lift if i asked my old shop teacher haha), but the belts...just something im not comfortable with yet
Old Mar 4, 2011 | 03:19 PM
M8NSTER's Avatar
You don't need to change the belts. That's at 60k.
Derek is right. Do it yourself (ask for help on here), it's easy.
Don't know about the bushings.
Old Mar 4, 2011 | 03:27 PM
llDemonll's Avatar
mmm, well if it's not belts then i suppose there's no reason to take it anywhere. i have one squeaky pump / belt / something but only hear it in the mornings when the car hasn't warmed up all the way yet, ill update later with a video of it. coming from passenger side of engine. sounds a bit like http://www.youtube.com/watch?v=zV3PV9yiakE but without the lifter noise (i mean obviously my car has some lifter noise, but it's overpowering in that video)
Old Mar 5, 2011 | 11:36 AM
yahu's Avatar
I thought I went over this in the "Introduce yourself to the people in the NW thread" The accessory belts need to be checked/replaced (if necessary) and the ACD fluid just needs to be checked. Timing belt replacement shouldn't be needed at 30k, unless for some reason the previous owner liked sharpening his blades on it.
Old Mar 5, 2011 | 11:45 AM
pao's Avatar
pao
i have the same squeaky belt issue - replaced it two times already and it always comes back - i blame the open hood for the issue really since it rains all the time here in wa
Old Mar 5, 2011 | 05:23 PM
js06evoix's Avatar
If I recall that noise is the belt touching the timing belt cover. The belt definitely doesn't get done at 30k. My buddy works for Mitsu, and said to just do the fluids and the spark plugs. I'd make sure if you do the ACD you do it with somebody who has done it before. That is one I definitely wouldn't do myself personally.
Old Mar 25, 2011 | 11:33 AM
llDemonll's Avatar
doing this stuff over the course of the next week or so, to make sure I hit everything:
oil change / oil filter change
rear differential fluid change
tranny fluid change
clutch fluid change
brake fluid change
radiator fluid change
I'll be figuring out what on the serpentine belt is squeaking after i buy the stethoscope and listen around, but is there anything important that I'm missing from the list above?
Recommendation on fluids? I've read that going with OEM stuff is best, and synthetic (dont remember exact weight for evo atm) from higher-quality oil (amsoil, castrol, etc; people said not mobil1)
Old Mar 25, 2011 | 11:45 AM
D Grade's Avatar
Alot of higher HP guys use the heavier weight Amsoil or Brad Penn. But at your power level I don't think it'll be as crucial unless you regularly track the car. Perhaps the Amsoil 10W-40 high zinc full synthetic would suit you if you do.
Old Mar 25, 2011 | 12:06 PM
llDemonll's Avatar
Just got back from lunch, forgot to glance at what was being put it in by previous owner. Yea, stock power, no track days
Old Mar 25, 2011 | 12:17 PM
D Grade's Avatar
You'd be good to go with Mobile1 10W-30 synthetic with either an OEM, K&N, Mobile1, or Wix/Napa Gold filter. I used Mobile1 10W-30 synthetic in many different cars for years with no issues or complaints. I recently did a switch to Amsoil 10W-30 synthetic with a Wix filter with no complaints. In fact Ill probably stick with it or upgrade to the 10W-40 high zinc Amsoil synthetic and either Wix or Amsoil filter (if I can find one) next change.
Old Mar 25, 2011 | 12:33 PM
llDemonll's Avatar
I've heard/read that Mobil1 got rid of phosphates (I think that was it?) in their oils and they aren't nearly as high of quality as they used to be, which was why i was thinking of going with Amsoil
Old Apr 17, 2011 | 01:37 PM
llDemonll's Avatar
Oil
Mobil1 10W-30 (Don't know part number)
4.8-5.0 Quarts
OEM Filter MZ690116
Manual Transaxle Oil (Transmission)
DiaQueen NEW MULTI GEAR OIL MZ313376
3.0 Quarts
Transfer Oil (Transfer Case)
Diaqueen LSD Fluid 3775610
.63 Quarts
Rear Axle Differential Oil
.58 Quarts
Power Steering Fluid
Mitsubishi Power Steering Fluid ACH1ZC1X04
1.1 Quarts
Clutch / Brake Fluid
Mitsubishi Brake Fluid DOT3 MZ311987
As Needed Capacity
Those are what I'm planning on buying this week, is there anything on there that should be changed? DOT4 brake/clutch fluid?
Old Apr 21, 2011 | 08:58 AM
llDemonll's Avatar
QuantityPart #DescriptionListUnit PricePrice
3MZ690116Oil Filter$5.75$4.38$13.14
13775610Oil, Lsd (4 Liter$49.05$37.38$37.38
1MZ313376? Manual Trans Flui$94.55$90.45$90.45
1PK5WASHERDrivetrain Washer Kit$15.61$11.89$11.89
3MD050317Gasket,eng Oil Pa$1.65$1.26$3.78
That's what I'm planning on buying, and then DOT4 fluid for brakes / clutch, does that all look right? I'd ask RussellM but he's been out of town and I'll need this before he returns
Chrushev
Lancer Troubleshooting
Mar 7, 2017 11:32 AM
Masheen
Mitsubishi TC-SST Discussion
17
Mar 11, 2016 08:12 PM
ChUt26
Jan 17, 2014 11:06 AM
GgreyEVOIX
Mar 7, 2010 08:22 AM
Pure Playaer
74
Nov 25, 2009 08:17 AM
