Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Noob Question ^_^
Old Aug 6, 2011 | 11:43 PM
kimsan808's Avatar
Noob Question ^_^
I'm thinking of retrofitting the JDM 8 MR headlights, and was wondering what size is the low beam bulb, I know that they're D2S housing, but the website is still asking me the options of H1, 9005, 9006, H11, H7.
Here is the link:
http://shop.lightwerkz.net/product_i...products_id=59
Thanks in advance,
Tony a.k.a. Krazy Korean
Old Aug 7, 2011 | 08:10 AM
F0RSAKEN's Avatar
D2S is a HID bulb, I think the ones you listed are all halogen. Try setting your vehicle as a 2006 Evo 9, with HID's.
Old Aug 7, 2011 | 08:24 AM
jdmEviL8's Avatar
i has a confused...
do you currently have the JDM 8 heads or have the OEM that you are going to paint the inside housing?
Old Aug 7, 2011 | 08:59 AM
kimsan808's Avatar
Thats what I thought, I guess I just have to call them up to narrow it down.
Originally Posted by jdmEviL8
i has a confused...
I have the JDM 8 MR's, the retro fit is only for changing out the crappy projectors for some Acura TSX's
Old Aug 7, 2011 | 10:17 AM
F0RSAKEN's Avatar
You shouldn't need to retrofit anything, JDM MR should be HID too.
Old Aug 7, 2011 | 10:43 AM
kimsan808's Avatar
Yes I know, I have afermarket HID's now, my USDM Headlights were non-HID's, then got the JDM's, but unfortunately the JDM projectors doesnt spread the beam evenly, it has a lot of weird focus points, where the retro fit TSX projectors has a smooth and even beam pattern. Also, the stock USDM non-HID bulbs are, I believe, are not D2S's where the JDM's are D2S's so I have to convert the whole thing anyways. All in all, I just want to see better on the road with the JDM's
Old Aug 7, 2011 | 11:05 AM
Lowso's Avatar
Post info when you figure it out because I will be doing the same when I get my Jdm heads.
Old Aug 7, 2011 | 11:39 AM
kimsan808's Avatar
Will do
Old Aug 7, 2011 | 12:22 PM
03Evo8DTC's Avatar
you just need to change the height of the headlight, the projectors wernt set i left them stock and theyre fine. Very good fill also, adjust the height and such and they will be even. lol i left them because i didnt mind where the lights shot, the hid is a D2S which is your main bulb, the inner most foglight is a H11 stock with the JDM its a 9006. and your high is the same as stock.
Old Aug 7, 2011 | 03:55 PM
kimsan808's Avatar
Thanks Keenan for helping with the numers of the bulbs I'm not saying that you cant see with the JDM's, I just always wanted to upgrade with the TSX projectors because the beam spreads out a lot smoother and evenly, and showed more lighting, I just like to be a bit more on the safer side.
Old Aug 7, 2011 | 04:01 PM
kimsan808's Avatar
Oh yeah, what is the harness type of the non-HID light? I think that was what they were asking.
Old Aug 8, 2011 | 01:10 PM
03Evo8DTC's Avatar
no idea lol im sure its on here though
Old Aug 8, 2011 | 04:55 PM
kimsan808's Avatar
Haha, thanks Keenan. I've tried looking everywhere, and its only showing me the numbers for the HID, and not the non-HID harness number. Does anyone know the number for the non-HID harness???
Old Aug 9, 2011 | 12:00 AM
yahu's Avatar
I've also wanted to do the TSX mod. Very brilliant looking when completed. I might have to look into that in a bit.
As for JDM headlights, I've noticed mine are reverse than my OEM (which makes sense) so that it illuminates further down the road on the driver side. US cars will typically have a beam pattern that illuminates the passenger side further than the driver side, so you aren't blinding oncoming traffic.
*edit - I've been meaning to adjust them, but haven't taken the time.
Old Aug 9, 2011 | 03:10 PM
GTisRule's Avatar
I have the non-HID lights too, and they're not very bright at all... on the edge of suck...
