AE86 Toyota Corolla Rally Car Build...
4 Attachment(s)
This is the car that Billy's NW chat photo is from. I am Timm, the builder. Feel free to comment, ask questions, whatever. I even accept donations :D
Anyway... here it is. __________________________________________________ _______ Ok, Heres the car as I got it, and the engine bay... Attachment 296099 Attachment 296100 Attachment 296101 And finally, the one action shot my brother got.... Attachment 296102 |
9 Attachment(s)
Cool, its up now. Here is the rest of the build.
Heres some of the car before the gutting. Luckily that didnt take too long, as there wasnt much of an interior to begin with. Attachment 296090 Attachment 296091 Attachment 296092 Attachment 296093 And here are the "gutted" pics. And yes, if it's visable... I know I missed that one bracket behind the drivers door. haha. I'll get it! Attachment 296094 Attachment 296095 Attachment 296096 Attachment 296097 Attachment 296098 |
That hammer should keep Billy in line! a few smacks to the head a day should do it.
Sounds like it's going to be a kickass project, need more pics of the cage! |
More pics are definitely on the way, I just need this spam guard to go away ;)
Some quick specs: Toyota 4ag 1.6l engine DOHC. N/A. Its actually 1628cc with the pistons in it. Small port head for higher intake velocity Individual throttle body intake. Custom air plenum eventually. WEB Cams, 110 Grind. 256 @.050 and about 10.1mm of lift. Wiesco Forged pistons, 81.5mm and ~12:1 static compression. Might be a bit lower, I need to re measure everything, its been awhile. Stock redtop con rods. These engines were designed to spin to ludicrous speed. Stock con rods are fine. Toda valve springs. Can we say 9.5 redline? (shouldnt have to go that high. I really hope not... lol) Yaris 1 piece bucket lifter conversion. The stock setup uses shims on top, and the lobey shaft can flip them off and destroy everything. Stock crank. See con rod description. Rebaffled oil pan w/ small port head's oil drain attachment. Modified stock valve covers to have 2 breather fittings for my catch can Either a TRD 4-1 or OBX copy 4-1 or custom tri Y exhaust header. I think. The jury is still out on this one. I think thats it. I'm sure I've missed something. ViPEC v44 ECM Direct injection Direct or wasted spark. Haven't decided yet. Custom Wilwood Powerlite brake system up front 1st gen celica supra rear brakes. Dual master cylinders, tilton Custom pedal for the DC made with a wilwood balance bar. Hydraulic hand brake Inline limiter Fully stitch welded body shell Full 10pt roll cage as per NASA rally rules Custom dead pedal Custom Co driver foot rest Custom Steering column support bracket Turreted rear suspension Custom Seat pans to get the floor lower Custom Seat rails to take full advantage of lower floor Lexan rear quarter windows JVAB Rally Spec Coil overs for all 4 corners. Reinforced front control arms Stitch welded crossmember w/ welds on steering rack brackets Custom 4 link setup in the rear 1st gen Celica Supra rear axle, 7.5" as opposed to 6.7" Stock LSD for now, Kaaz in future Stock 5spd T50 tranny ACT HD 4 puck solid center clutch Custom driveshaft Fuel cell and all aeroquip lines SARD fuel pressure regulator Walbro Fuel pump(s) Some sort of bigger injectors. Maybe 7mge 330cc/min Custom wiring harnesses and a bit of new switches and toggles for various things Aux lights Custom exhaust Hi flow cat Aluminum sump guard HDPE underbody All sharp edges skiplated Shock thread protection That's what I remember so far. I'm sure I'm missing something. Or a few things, haha. |
3 Attachment(s)
And here are some more pics...
This is the axle after some clean up Attachment 296086 Attachment 296087 Basically, I've just cut off the stock 4 link brackets but left the pan hard and sway bar mounts. I've also been grinding the remains down to the axle level and wire wheeling away the rust. It was only a lot of flakey surface rust, so nothing too bad :) Heres the "artistic rally parts shot" haha Attachment 296088 |
my bad... double post. Spam eater didnt eat it after all
3 Attachment(s)
This is the usual steering lock/ignition bracket on the steering column. Note the little "Bridge." This is where the lock lug lives. Well, to steal a corolla, erm, I mean, to disable it for legal purposes, you can just cut the bridge, and pop the lug out.
Attachment 296083 Well, in rally, you cant have the steering lock, and as I'm too lazy to turn a ket to start my car... I've modified that bracket a bit. Presto Chango we have-o a steering column *spacer* as the turn signal lever bolts to this peice. Attachment 296084 Attachment 296085 As you can see, I no longer have the "bridge" or the turn key section. |
5 Attachment(s)
Here is the heater box problem..
Attachment 296078 Attachment 296079 Attachment 296080 Attachment 296081 Attachment 296082 So there lies the problem. If its possible to move the blower those few inches inward, I would just do that, but I dont know how feasible it would be... I think instead of trying to fab a new hole, or make a duct I would rather just get a smaller, lighter, heater for the defrosting purposes. |
6 Attachment(s)
Ok, these are the strut tower reinforcements. The plate on the side is for the roll cage tubes that come through the firewall. (Take that Jesse! haha) The other peices are to help with the constant pounding the tops will take.
Attachment 296072 Attachment 296073 Attachment 296074 These are the 30 inch links... There are also some shots of the brackets (I'll get better ones later) Attachment 296075 Attachment 296076 Attachment 296077 https://i86.photobucket.com/albums/k...ld/DSC0082.jpg |
3 Attachment(s)
Here is the rear turret. I've only got the right side done so far
Attachment 296069 Attachment 296070 And the boxed control arm Attachment 296071 |
5 Attachment(s)
Ok, here's what im doing to get my seats lower. As you can obviously tell, I chop giant hole in floor... and insert new floor pan i bent up.
Attachment 296064 Attachment 296065 I took my LSD apart, time for a rebuild and some shimming Attachment 296066 Attachment 296067 And before anyone asks, No, it will NOT be put back together in that mess of an area. And a random pic of my stitch welding. This is with my TIG :) PS on the A piller ;) Attachment 296068 |
3 Attachment(s)
Brake stuff came yesterday... and I got around to tigging the brackets to the rear end. Oh, and the cage is more completed. Pics soon, tonight if photobucket doesnt hate me.
OK, here are the pics! Tig'd on 4 link brackets... Attachment 296061 Attachment 296062 The brakes. Attachment 296063 I'll be using those for the front, and stock supra axle brakes for the rear. That gives me slightly less then 50/50 bias (towards the rear) so then I'll just dial in the braking I want with the limiter and balance bar, and be good to go. I also bought one of these... http://www.rallysportdirect.com/shop...sparco3251.jpg |
4 Attachment(s)
Here are some pictures of the cage so far. The door bars, the upper half of the sill bar, the A pillar support bar, and the main X/harness bars are not welded in yet. This is so I have an easier time getting around inside the car to install the seat mounts and covers for the 4 links. Hopefully next sunday the car will be getting its logbook, meaning the cage will be DONE. Finally. Its been long... and hopefully its drawing to an end.
Attachment 296057 Attachment 296058 Attachment 296059 Attachment 296060 More to come. Oh, I also ordered a ViPEC ecm from Bob and will be running that :D Double OH, Koyo Radiator came too. Well, and I guess technically the master cylinders TRIED to come... but they sent the wrong ones... so, hopefully the RIGHT ones get here soon. :D then I can start fabbing the pedal mods... |
7 Attachment(s)
Heres the difference in brake diameters.
Attachment 296050 Attachment 296051 Ok, so in order to get more powerful brakes with an increase in heat capacity (thermal mass), I had to get different calipers and rotors. The thermal mass part is easy, a wider disc, or a bigger diameter disc, or both. However, because a larger diameter disc will also effect FR RR bias, I didnt JUST want to get some massive disc. Besides, this being a race car, why should I care how cool it looks? lol. Anyway, another consideration was the wheels I want to run. The rallies here are run on gravel, so clearance around the outside edge of the caliper is important, otherwise you eat the calipers faster. All of this went into deciding a caliper to use, and a rotor diameter. I choose the powerlite because it would fit well, and a 10.04 rotor because, well, thats the closest rotor I could find that I could make work without having to buy expensive AP 254mm x 20.1mm rotors. Even though thats the size I was aiming for. We found rotors from a camry, I think it was that were 10.04in in diameter, and .86 in thick. The problem was not many rotors that bolt to the back of hubs are small enough, and the ones that slip over the lugs are the wrong bolt pattern (as in this case). So... I threw it on a bridgeport and bored my own 87mm bolt pattern in it to bolt it to my hubs, and bored out the center hole so it would FIT on the hub. Attachment 296052 Insto rotor for 35 bucks. The rear of the car has the stock supra rear end rotors and calipers. The rotors are a 10in disc as well, but only .38 wide. Plenty, for the rear brakes. The front calipers are a 4x1.38in piston and the stock supra are a slider with a 1.6875in piston. I dont remember stock sizes... they might be in my other post. The other cool thing is by using the stock supra rears, they are iron, and the gravel wont eat them as fast. Good for RWD. Also, I can use the stock parking brake and not have to figure out how to make my hydro handbrake lock, haha. (Fun fact, the STI I crew for, its parking brake is a bungee cord from the handle to the steering wheel.... 75k rally car... and its got a bungee cord, haha) More Cage pics Attachment 296053 Attachment 296054 Attachment 296055 Attachment 296056 |
2 Attachment(s)
Oh snap!
Attachment 296048 Attachment 296049 Standby for door bar pics. Both continuous bars are in... And soon one of the lower bars. A few gussets are made. |
