3 Attachment(s)
Well, its logbooked!
I just need to make 4 more gussets, then brace the A pillar to the half laterals, the B pillar to the main hoop, and possibly a few other spots. Attachment 296045 Attachment 296046 Attachment 296047 |
3 Attachment(s)
Here's what I did today, with some help of my friend. I taught him how to use my plasma cutter and let him loose on laying out and cutting these little guys.
Attachment 296042 Attachment 296043 Attachment 296044 There just some 18 gauge (I have lots of gusset material left over, haha) "house" shaped pieces, I clean the edges up and then bend them in the brake. I did have to trim the passenger side one a bit to clear a firewall bump, and a stitch weld. Oh, and on the driver's side you have to be careful to make it so you dont weld over the steering column boot hole. I still need to make the last few gussets for the roll cage, but plasma cutting the round parts owns me... so... it takes time, haha. |
3 Attachment(s)
And here are the little braces I made real quick
Attachment 296039 Attachment 296040 Attachment 296041 |
Whoops. Cheated the system and this didnt get cancelled
4 Attachment(s)
7 Attachment(s)
Attachment 296028
Attachment 296029 Attachment 296030 Attachment 296031 Attachment 296032 How it will connect to the dashbar... Attachment 296033 Attachment 296034 Seat mount "frame" bars IN Seat mount's figured out (corollas suck for race seats...) Dash acquired and cut to fit, one bracket fabbed, need a few more Front Pin mounts done Rear pin mounts have the hole drilled, and thats it Dash bar located and welded. Steering column attachment fabricated. Half attached. Kind of. A pillar gussets fabricated and installed Fuel cell cage IN Trunk floor patched around cell cage I'm sure im missing something, but there is the gist of things |
5 Attachment(s)
Attachment 296023
And a bit more progress... My Dad has been feverishly working on the brake pedal while I've been working on all sorts of other stuff... He's gotten the balance bar adapter in and welded, and tacked the frame up for me to weld. I'll get some more pics of the assembly when its right prior to paint, and after. Here is the pedal, ready for paint and finishing, but i was checking clearance for the steering column. Everything was good! Attachment 296024 And the reinforcement plate for the firewall, well, at least part of it... I may be running a small tube to the strut tower depending on flex. Attachment 296025 Here is the bracket I fabbed for the steering column Attachment 296026 Attachment 296027 Its finally living in it's little home... :D I'll get some more pics soon. |
8 Attachment(s)
Well, got the dead pedal fabbed and installed today.
Attachment 296015 Dead pedal Attachment 296016 Inside... sprayed with weld thru primer to help keep rust down. I forgot to do this to the steering column bracket. Oops Attachment 296017 Tig welded top. Kinda tall welds... too much rod Attachment 296018 checkin out its home Attachment 296019 gotta check the angles out Attachment 296020 Its moved in! Attachment 296021 Solid foundation Attachment 296022 Strong attachment up top That's pretty much all I did today. I moved a bunch of stuff around so I can finish building the rotissorie to finish the underside of my car. Overkill? probably, but hey, the metal was free. |
So thats where I am now. I'm almost ready to get the car upside down to finish a bit more fab work. As I put the pictures up here, I noticed there are a lot that I dont have up, like the 4 links and the turrets. I'll have to get some of those.
I will be watching this build ;)
Timm is only allowed out of the garage for so long every day... he has almost used all that time up today :lol:
Originally Posted by Billy@EnglishRacing
(Post 7262909)
lol I'm actually going up to a some suby dyno/shop opening thing with my cousin today. But I'll get SOME work done tonight. Maybe I'll throw up some CAD drawings of stuff im working on... :D |
Looks good so far....should be a good setup.
Thing is sick, mad props for the build
looking good
