Hood Struts
http://club.autohome.com.cn/bbs/thre...4998727-1.html
here is the link from where I saw it..it's all in chinese just scroll down to the pictures...
Ok, so I poked around under the hood, and realized that the mounting location he chose looks promising. Upon further inspection, I noticed that there are no two holes that are equal reciprocals of each other. Too high, too low, forward, back, whatever, but no two are even.
So I came back in and looked a little closer at his pictures, and you can actually see that his two struts are not mounted evenly. I'm quite skeptical about how such a set-up would perform.
There HAS to be a do-able combination of these 2 links to make it work for our vehicle ! ! ! ! !
http://www.autozone.com/autozone/acc...mString=search
Like how these ones are attached:
I measured the distance from the hood brackets to the holes approximately where he (the guy with the ASX in China) mounted the rams, and the D/S was 20", P/S was slightly less, I want to say 18", but that seems too short. I'll check it again later tonight.
From: Out towards the countryside of Dallas, TX (USA)
One of the things that's not obvious on first inspection is the fact that there is an "extension" to the hood hinge on their ASX.
Either it is custom fabricated or it comes from factory on the Chinese model...
This small "bracket" is Really needed IF we want/expect the struts to hold up our hoods Safely!
Without this "small" distance, the angle at which the strut would end up holding the hood at too acute an angle and risk accidentally "collapsing" prematurely.
Would depend on the length/brand/etc. of your hydraulic struts. Cheap/weak ones would most likely need more assistance than a high dollar one.
Better to overbuild than to regret with wimpy units.
I've got struts meant for the BMW X-series because I'm just not very comfortable knowing the amount of force/weight they will have to lift at the angles that I see currently. (I had a Buick Century hood come down on my hand once because its hood strut gave out, and THAT was the most scary moment of my life. I thought I lost my fingers..)
Here's a comparison of the X lifts compared to our stock rear hatch units:
Found the store where they sell the strut in china
Here is the pic of the install strut maybe it will give you guys some idea of where the mounting area is...
Off topic I really like the retractable trunk lid/cover
Last edited by Burtonrider1002; Sep 24, 2013 at 12:32 AM. Reason: Accidental, no changes made
