Stereo install 2015 OS
Old Mar 20, 2015 | 07:22 PM
wowagorilla's Avatar
Anybody install a new radio in your OS? I just purchased a 2015 ES and am trying to install a Kenwood DVD double DIN radio. There seems to be no antenna wire( it must be in the wiring harness.) I can power up the unit fine but i cant seem to locate the antenna wire. I have done several aftermarket radio installs but this is a head scratcher.
Old Mar 20, 2015 | 07:41 PM
I meant to say the USB wire. NOT antenna wire. Sorry.
Old Mar 23, 2015 | 11:35 AM
Never mind. I got the radio in. I don't know what the other two harnesses are for, but everything is working. If anybody has any info on the remaining wires or what wires would plug in for a rear view camera that would be great.
Thanks
Old Mar 25, 2015 | 05:50 AM
303Casper's Avatar
Thanks
If your doing aftermarket back up cam. There should be a reverse wire on the stereo. And one video input for back up. Acc wire for the cam and a ground and that's all your need. As far as factory back up cam you may have to do research and figure that one out. There may be a adaptor to make it work. But I wouldn't know who makes one
Old May 5, 2015 | 06:48 AM
migs647's Avatar
What install kit did you use? We have a 2015, I was thinking of getting this ring to get a double din to fit, but unsure: http://www.sonicelectronix.com/item_...9-7015CHG.html
You didn't replace the entire front piece like 11-13 did you?
Old May 10, 2015 | 05:39 AM
Ltiller14's Avatar
What dash kit and wiring did you buy? I can't find an installation kit for the 2015 anywhere! I just bought the new double din Pioneer AVH-X2700BS head unit
Old May 10, 2015 | 05:40 AM
Ltiller14's Avatar
If you buy this and get it to work, please let me know
Old May 11, 2015 | 06:58 AM
migs647's Avatar
I have ordered it, will let you know
Old May 24, 2015 | 06:19 AM
jnoel0384's Avatar
Here are the wiring diagrams for your 2015 ES i will post the 2nd one below this post
Old May 24, 2015 | 06:20 AM
jnoel0384's Avatar
Old May 25, 2015 | 05:40 PM
peracer's Avatar
I did an install on my 2014 OS using the regular Outlander kit listed. It is not an exact match. I had to use the mounting brackets off my factory stereo in conjunction with this kit. All in in all, it worked out pretty well and I didn't have to spend a ton of money.
Old May 26, 2015 | 06:51 AM
migs647's Avatar
That's cool, I figured we'd have to use the factory mounting brackets. So everything is flush peracer?
Old May 27, 2015 | 09:35 AM
I installed a kenwood double din. I did not use a dash kit. I bought some sheets of black ABS plastic and i am making my own trim ring. I did not want to replace the whole front piece.
Old May 27, 2015 | 02:18 PM
peracer's Avatar
It looks pretty good. It sits flush, but if I were to be picky, I would say there is a small gap at the bottom. Maybe a 1/16" to 1/8". You don't really notice it.
Old May 28, 2015 | 06:51 AM
migs647's Avatar
^--- you can use the Outlander kit so you only ADD a ring as confirmed above. $20 for the kit, doesn't replace the whole thing.
