Transmission fluid for 2015 2.0 sport
Old Dec 15, 2016 | 04:56 PM
fujirio's Avatar
Well this work https://www.amazon.com/gp/aw/d/B00T9...smission+fluid
It's castrols cvt fluid and I don't want to fork over tons at the dealer. Also what's the capacity. I want to change it this weekend if I can. Thanks
Old Dec 16, 2016 | 04:06 AM
Nast_Nas's Avatar
DO NOT USE THAT FLUID. Only use oem cvt fluid or the eneos cvt fluid. And you're going to need about 7-8 qts. You can get the enoes in a 6qt case and then buy 1 or 2 single qt bottles
Old Dec 18, 2016 | 04:17 PM
fujirio's Avatar
I drained it and only 4 quarts came out. is it 7 quarts or just put 4 back in?
Old Dec 19, 2016 | 06:34 AM
Nast_Nas's Avatar
Just put what you took out. When you fill it it'll let you know how much is in there. I'm going to guess that you didn't drain some out the cooler lines?
Old Dec 19, 2016 | 05:32 PM
fujirio's Avatar
no, i just drain the plug. so weird because amsoil says capacity is 3.7 quarts....
Old Dec 19, 2016 | 05:40 PM
Nast_Nas's Avatar
oh ok. well the whole trans and cooler combined is like 7-8 qts, but you really cant drain the whole trans without really taking it out lol, so theres always a little old fluid in there. but as long as you drain the plug and the lines put some good fluid in and go through the fill and cycle process youre always good
Old Dec 19, 2016 | 05:44 PM
Nast_Nas's Avatar
draining from the plug you should get somewhere close to 5.39 qts so i say somewhere btw 4.5-5 since like said old fluid will still be in there
Old Dec 20, 2016 | 05:15 PM
fujirio's Avatar
thank you, it shifts so much smoother now than before. Kinda regret not doing this sooner.
EvilDSM97
Jul 16, 2016 06:10 PM
tdott
Outlander Sport
19
Dec 22, 2015 05:04 PM
stealthgray
Midwest Region
Sep 28, 2015 11:20 AM
a2b
Nov 14, 2012 12:33 PM
