Pacific Northwest General areas surrounding Bellingham, Seattle, Tacoma, Bellevue, Spokane, Yakima, Portland, Eugene, Bend, Medford
SSL aftermarket deck working but sub isnt...
Old Mar 31, 2012 | 08:20 PM
Mivo's Avatar
i have been scouring the forums and google trying to find a diagram to see if i can just wire the sup/amp to the deck but i am lost so wondering if anyone could help me out i have both harnesses needed the deck works fine. on the deck i have two rca marked "sub" but nothing to connect them to...
so just wondering if anyone local has had this issue and could help i can take pics as requested!
Old Apr 2, 2012 | 11:29 AM
RevMatcher's Avatar
What a coincidence, I have the same issue, and have been scouring the forum for some answers!
Bump to the top for you!
Old Apr 3, 2012 | 07:47 AM
M8NSTER's Avatar
You should not have to wire the amp to the deck. There is an adapter to connect your stock amp to an aftermarket deck. I've done this with my SSL.
What is the model of deck (help me to find which adapter you need)?
How do you know it works? From another car, or it's working in your evo?
Old Apr 3, 2012 | 08:06 AM
RevMatcher's Avatar
Hey,
I'll have to open up the connections to check what's behind. My evo had an Alpine 9883 installed when I purchased it. I realised the sub isn't working when I removed the sub last weekend, and there was no change in quality of my music!
Old Apr 3, 2012 | 09:29 AM
M8NSTER's Avatar
Yeah, the stock sub is pretty easy to notice. Make sure to check the connection between the stock amp and sub (under drivers seat).
That deck you have should have the standard RCAs outputs in back to attached the adapter.
http://www.amazon.com/Metra-70-7003-...ar=1&carId=001
It's the adapter on the left. The round black side goes to the stock amp, and the 4 RCAs go to the deck.
Old Apr 3, 2012 | 09:31 AM
RevMatcher's Avatar
Thanks. I'll check this out. If I have this type of adapter and the connections are good, what's the next thing I should check?
Old Apr 3, 2012 | 10:59 AM
M8NSTER's Avatar
Not sure if the stock amp has fuses on it or in the fuse box, but check those. Check all the connections from amp to sub (I can only remember 2, on amp and right above where the sub is). Also check to make sure the sub isn't blown (damaged).
BlownSaleen
Lancer Troubleshooting
Apr 30, 2011 06:24 AM
06_RALLI///ART
26
Feb 6, 2008 06:39 AM
blackixevo
Dec 23, 2007 03:44 PM
RyanEvo2006
Dec 28, 2006 02:43 PM
o6RSEvo
Nov 4, 2006 08:18 AM
