Pacific Northwest General areas surrounding Bellingham, Seattle, Tacoma, Bellevue, Spokane, Yakima, Portland, Eugene, Bend, Medford
Radiator advice needed.
Old Feb 4, 2013 | 04:45 PM
Uryelowducky's Avatar
My stock radiator just went out. It's leaking at where the plastic and metal joins right beneathe the radiator cap. No cracks that I can locate , just know that it oozes out when I start the car. Been looking around for a new radiator and can't find one straight answer.
Anyone point me in the right direction? I'm looking for something affordable, I no longer care about performance, just drivability.
What radiator should I buy? Will it reuse my stock fans? Any help or input is appreciated. Thanks.
Old Feb 4, 2013 | 05:02 PM
nemsin's Avatar
CBRD makes a great evo radiator http://www.cbrdspeedfactory.com/CBRD...ution-8-9.aspx
Old Feb 4, 2013 | 05:20 PM
That's a bit out of my price range and needs. Any other reliable choice
for lower?
Old Feb 4, 2013 | 05:25 PM
RaptorReed's Avatar
Just buy a new stock radiator then.
Old Feb 4, 2013 | 05:32 PM
nemsin's Avatar
http://www.maperformance.com/mishimo...l#.URBgzqU81gg
Old Feb 4, 2013 | 10:49 PM
codgi's Avatar
The mishimoto's are hit and miss it seems. Some people have had great luck wit them...others haven't. OEM or Koyo would be cheaper than CBRD's.
Old Feb 4, 2013 | 10:54 PM
evosmoothie's Avatar
i have koyo evo 4,5,6 radiator i think i paid 250-300 for it ets sells one and youll need a slim fan ets also sells that for 60
Old Feb 5, 2013 | 03:20 AM
tkklemann's Avatar
I have the same radiator and I must say I have really liked it since I bought it.
Old Feb 5, 2013 | 10:33 AM
kimsan808's Avatar
I have a Mishimoto, no hiccups on it since the 3 years I had it, make sure to get the radiator that can fit the straight top hose instead of the standard route on the stock radiators, just so that the hose don't heat up as bad.
Old Feb 5, 2013 | 02:03 PM
boostedwrx's Avatar
I have an OEM radiator sitting in my garage from my Evo 8...
Old Feb 5, 2013 | 02:13 PM
SilverShadow03's Avatar
Get ourself an OEM replacement or OEM comparable replacement...I replaced my evo 8 rad with aftermarket oem replacement for less than $100. Still going strong after 2+ years...all I needed to do was enlarge the two holes the stock fan slides into at the bottom... took a few minutes with a larger drill bit...DONE.
www.diyradiators.com
Just found my receipt $96.04 shipped for my 03 rad.
Old Feb 7, 2013 | 02:45 PM
This guys is selling his OEM Rad for $100.....USED but in good condition (per his post).
https://www.evolutionm.net/forums/sa...take-look.html
Old Feb 7, 2013 | 03:02 PM
boostedwrx's Avatar
OP if your in Fed Way I'm in Des Moines.
iLLevo_
Oct 20, 2017 11:58 AM
EvoDan2004
32
Mar 15, 2016 08:32 PM
idanno
Evo X How Tos / Installations
22
Nov 6, 2014 01:04 AM
KevinD
11
Apr 21, 2008 12:45 PM
Reignman
12
Jun 14, 2004 04:10 PM
