Pacific Northwest General areas surrounding Bellingham, Seattle, Tacoma, Bellevue, Spokane, Yakima, Portland, Eugene, Bend, Medford
help needed in spokane wa.
Old Dec 20, 2013 | 02:19 PM
cmiller10's Avatar
Hey I'm new to evos and I need help getting my clutch changed. For some.reason the tob will not let go if there is.anyone near please help me. I have access to a heated shop and ill pay you if u help me get it out. Thanks
Old Dec 20, 2013 | 04:26 PM
neogeo64's Avatar
Are you on NW EVO Facebook group? I know there are a few members on there that are out in that area.
https://www.evolutionm.net/forums/northwest-region/594454-nwevo-facebook-page.html
Old Dec 21, 2013 | 07:00 PM
cmiller10's Avatar
sure aint but will be lookin it up now.lol
Old Dec 22, 2013 | 10:32 AM
evo_dad's Avatar
I know of a couple people up there. I will see if i can get ahold of either of them for you.
Old Dec 22, 2013 | 07:45 PM
cmiller10's Avatar
thanks id appreciate it. I don't want to drop the 2020 to get the clutch changed.
Old Dec 23, 2013 | 12:23 PM
jbuhrman's Avatar
I know when we pulled the trans on mine few weeks ago the wave collar wouldn't disengage, had a hell of a time getting it off.
I'll bet the same thing is going on with yours.
Old Dec 23, 2013 | 01:00 PM
sr20det91's Avatar
Damn, your about a week too late. I was over at Fairchild AFB for about a month. I would have been happy to help. Here is a quick tip though, make sure you have a good flat tip screwdriver and that your inserting it in the correct spot. Between the wave ring collar and the TOB. Once you have it in there and turned 180 degrees give the release fork a good shove in towards the engine. Sometime you may need to rotate the the motor so you can give it a pry on both side of the ring. Sometimes it's a pain,but you will get it released with a little patience. Good luck!
Old Dec 23, 2013 | 01:22 PM
Ev0ikon's Avatar
Many times I cursed while laying under that #$(%ing inspection hole and jiggled the #$%ing flat-head screwdriver... damnit that brought back memories... :}
Old Dec 23, 2013 | 04:55 PM
cmiller10's Avatar
ive been under mine for 3 weeks every weekend. lol I want to drive the damn thing now.
the problem im seeing is that the tob doesn't get close enough to the pressure plate to get it right. I also used a pry bar on it so its really really stuck.lol
Old Dec 23, 2013 | 05:03 PM
cmiller10's Avatar
sr20det91 u drive that white one that was parked at the inn? cause mine is the red one that was parked at the shop.
Old Dec 24, 2013 | 09:15 AM
sr20det91's Avatar
No, I didn't have the EVO with me when I was out there. I was doing some SERE training so I had flown out from DC. If you can't get it to release your only other option is to get a flexible extension and unbolt the pressure plate through the access hole. It's a pain in the ***, but possible.
Old Dec 24, 2013 | 11:23 AM
Supergoslow's Avatar
so far I've only done one that wasn't a huge pita! but a less preferred method which I did on my stock clutch was a chisel punch where you would put the screwdriver, a socket on the end of the punch, and a LONG pipe for leverage.
you'll end up breaking the waveclip (which is easier said than done) but after busted knuckles, blood sweat and almost tears, it was worth it haha
Old Dec 24, 2013 | 01:31 PM
cmiller10's Avatar
yea some one told me to do that too. is it easier if I take off the shield cause I don't even see any of the bolts. and some one told me that they used an air hammer and beat the bearing until it let go.lol but I can break that wave clip? cause that's prob the easiest thing right now.
Old Dec 25, 2013 | 07:40 AM
by shield do you mean starter plate? or the small shield on the bottom. you can't get the starter plate off and removing that shield won't show you anything but the flywheel.
I would strongly disagree with the air hammer method because that would put an ungodly amount of direct vertical pressure on your input shaft. when using the chisel and lever you're utilizing the same concept as the screwdriver only with more ****.
breaking that waveclip isn't easy but it's what I did and it only took about 15 minutes after trying to pop it via the preferred screwdriver method and rotatin the engine a million times. good luck!
Old Dec 26, 2013 | 01:38 PM
cmiller10's Avatar
is it just a matter of over powering it or is there a trick to breaking it too? cause its prob going to be what I have to do.lol
