Originally Posted by k3lv
(Post 9303852)
sorry late reply I went on vacation. Your 8.5 definitely won't work, you'll need a lot of work to fit that, and I'd imagine you would also be sitting very close to the suspension with that. I'd pass on that setup unless you want your wheels further out and get body work done
Ot
I know this is a little off topic, trying to get another opinion about tire sizes before i go ahead and buy a set, 1st time getting a set of tires.
-Wheels : Motegi MR125 17x7.5 42 offset -Tires : Nitto NT NeoGen ZR 215 x 40 - 17 I'm sure these wont rub at all on my 06 ra from what ive read, but some tires and wheels sometimes might have a slight difference. No body kits, just have S-Tech springs on. Any suggestion will be helpful, thanks. |
^ you'll be fine
1 Attachment(s)
(Post 9312366)
^ you'll be fine
pics for the non-believers: http://i22.photobucket.com/albums/b3...laza/photo.jpg Attachment 313894 |
i personally inspected this today, i couldn't believe they fit, but they do, and good too...the rear was close though rob, i laughed when i stuck my pinky finger in between the wheel and the trailing arm, and it stopped at the first knuckle :lol:
they looked so good i thought he had spacers i didn't realize at first how deep the wheels were. |
Originally Posted by roblaza
(Post 9315109)
THIS. i have 17x7.5 +40 with nitto neogen 215/40/17's and they clear in the front AND back...but only by a cooter hair in the back. you'll be golden {thumbup}
pics for the non-believers: http://i22.photobucket.com/albums/b3...laza/photo.jpg http://i22.photobucket.com/albums/b3...a/IMG_0477.jpg |
Thanks, ordered them 2 days ago so they should be on soon.
what happens to the front fender liners? after you roll the fronts can the fender liners still be in there? :confused:
Don't need to roll fronts. There's nothing to roll there. Only in the back. I still haven't had mine rolled yet.
I mean on the original post with 17x9s
also wondering if you can get the -1 camber without coilovers? thanks
^ you can get camber bolts from a place like RRM. I'm not an alignment guru so cannot answer that one.
The fender liner is still there after it was rolled. Rubs like a ***** inside at full lock but it's still there |
hmm yeah i know you can adjust the rear camber from the factory. i will have to look into getting those bolts.
as for the fender liner, is it possible to remove it easily to service the engine? and with a pull wouldn't the top of the inner liner shorten because its being pulled wider causing it to rub more? i wonder how far off evo liners are... |
i also read on some of the evo forums that some people heat up the fender liners with a heat gun and mold them how they want them. the splash them with a water hose to get them to hold shape
