Originally Posted by joedr
(Post 6383407)
Wired mine up today and it is working fine!
I will post findings on the BR Race Core very soon.... well... as soon as I get to the dyno. jeje! |
Will do tomorrow morning and will let you know!
well both sensors should age at the same rate... and that should be pretty slow I would imagine.
mine is in and ready for the ECU to be patched - hopefully the one I did last night will "just work" :D... |
ok got my results from this morning.
Raw 2byte ADC was 657, MAF IAT was 15degs so 5*657/1024 = 3.21volts 3.21v = 16.5degs. Is that about right? Not sure why there is a difference between MAT and IAT?? |
Originally Posted by tephra
(Post 6384540)
I am actually using the scaling from http://www.bmotorsports.com/shop/pro...roducts_id/400
and then using the voltage divider formula "5*($Ohms/(2250+$Ohms))" to convert ohms -> volts ps - Iam just doing the XML update now, will shoot you and email - I am redoing the turbo section.. :) |
ps how certain are you on the 2250 ohm internal ECU resistance?
(Post 6384645)
(Post 6384676)
hrmm yes, but I think its more likely the 2250 is slighltly off.
Ummm I have some pictures of the ECU board - let me see if I can see any resistors on it :) Probably a 1-million shot but hopefully it will work.... :) |
I will check in the morning for the values again.
The car has been off for the last couple hours and both IATs are showing 95 F (engine off). |
Can we just unplug the sensor then measure the resistance across the pigtail to work out the ECU resistance?
ie, either pigtail (the one that works) to +5volt? that should give us the resistance of the ECU resistor? |
1 Attachment(s)
Huuum! After a few mins.... the AIT was showing 96.8 and MAT stayed at 95 F.
Just attached a 10-15 min trip log of AIT and MAT... that was done earlier today with temp around 80 degrees. |
(Post 6384924)
Hrmm I guess it would be too hard to find the +5v signal anyways.
1 Attachment(s)
The difference this morning was still 1.8 F between the two. The coolant temp was also set at 77 F.
This was after a few mins with the key on. See here.... Attachment 298777 |
