Josh you need to track down a 1.15 T4 for your car.
Interesting data, the 3794 may have been on the wrong side of the choke line as well at 55psi because it didnt hold it for very long. It definitely seemed happier at 52psi. Aaron |
Thanks for sharing!
I think FP sells them for $300 o something. Not to thread hijack but didn't I read somewhere that you posted that spool on a TS won't be affected on the size of the a/r.
Well its the 60% rule on spool so a 1.00 will act like a 0.60 where a 1.15 acts like a 0.69 A/r single housing. The advantage is out the top where it acts 90% of its size vs power.
Originally Posted by JohnBradley
(Post 10606642)
Interesting data, the 3794 may have been on the wrong side of the surge line as well at 55psi because it didnt hold it for very long. It definitely seemed happier at 52psi. Aaron |
Originally Posted by R/TErnie
(Post 10606915)
choke line. :)
(Post 10606915)
choke line. :) great test thanks for sharing
thanks for taking the time to do the test, and for doing it well at that.
Curious if you have any personal opinions on transient response in general. The PTE obviously looks less laggy, but I'd like to hear how that translates into transient, or if it doesn't. awesome stuff. |
Awesome results thanks for putting in the time to do this you guys rock and so does PTE
You're not going to go wrong with either of those really are you?! :lol:
Nice test - thanks for sharing :) |
Curious on the 55psi dyno #'s too. I wouldn't have even caught the 100ish whp difference between the Facebook post and this test if it hadn't been mentioned. I'm just curious which was the actual result.
Great test BTW, been looking forward to this release since you guys mentioned it on your FB page :) Very well done. Could you compare the air temp readings for each turbo at each boost level? It may help to show how steeply the turbos Efficency drops as you exceed certain levels. -Jamie |
Originally Posted by Dynotech Tuning
(Post 10608988)
It appears that the difference between the two identical results is about the same percentage. Might just mean the dyno shop migh have calibrated their mustang dyno to be closer to dynojet results but Boostin had their results show the standard mustang dyno's parameters? Just a guess.
-Jamie |
Thanks for sharing the comparison of these turbos! {thumbup}These turbos are my first choice but the PTE is cheaper, that's the reason why I only reason I got it if the price were the same I would have grab the 3794. lol
I wonder how much power/spool difference on twin scroll? |
1 Attachment(s)
Great comparison between these two turbos. Just curious why you didn't include this particular dyno sheet? Also wondering why the numbers on this sheet at 55lbs are different than the one you posted? The time on this sheet and the other one are identical, so why is there a 100hp difference?
