Originally Posted by davidbuschur
(Post 8874358)
The pan mod, if the car is apart is going to be beneficial to do, keeping the oil near the pick up surely isn't going to ever hurt.
Can anyone comment on this product that has ordered/installed it? |
Originally Posted by boomn29
(Post 8941797)
Agreed.
bump for a good product. im ordering one of these now. when you have a quick spooling torquey car you need all the help you can get to keep the pickup submerged at all times so it doesnt suck in any air.
mine has worked great so far! i also have the crank scraper
I think i will pick one up
Installed mine today, nice to have a brand new oil pan on the car along with more piece of mind that the oil is where it should be.
Thanks Curt, did you put a scraper on it too or did you have it already?
it would be good to note this pan is identical to the insanely high priced JUN pan as well.. so this pan definitely works well. JUN did lots of testing with it.. i had both pans side by side they both do the same thing.. i filled them both up with water and they both trapped it the same way when moving the pan back and forth. kudos for Buschur Racing for offering the pan at a affordable price for USA people.. JUN is out of their mind.
Originally Posted by David Buschur
(Post 9664156)
Yes, works well with the billet crank, a few small mods but you can handle it. I have one in my car.
sweet never new that. ill have to pick this up very usefull
(Post 8941797)
Agreed.
Can anyone comment on this product that has ordered/installed it? Had this installed earlier this year. Since then I've had 2 track events including 150+ mph at Road Atlanta. No problems; not 1 leak. Pretty happy right there actually. I've seen my Oil Pressure stay much higher and peak much higher. I've also seen my Oil Temps stay lower - about 10-15 degrees on average. Recommend; especially for the cost and as compared to other options out there with fitment issues. |
(Post 10135640)
Yeah, I can answer my own question from 2010 - It works great!
Had this installed earlier this year. Since then I've had 2 track events including 150+ mph at Road Atlanta. No problems; not 1 leak. Pretty happy right there actually. I've seen my Oil Pressure stay much higher and peak much higher. I've also seen my Oil Temps stay lower - about 10-15 degrees on average. Recommend; especially for the cost and as compared to other options out there with fitment issues. l8r) |
Originally Posted by Ludikraut
(Post 10135798)
Do you have data from the Autobahn South Course - turns 1-3 specifically? After running with r-comps I seriously need to address this - I was dropping down to about 25psi oil pressure.
l8r) |
What about from an "eyeballing" perspective? You say that it has improved, any guess as to how much? I.e., instead of hitting 25psi, do you now only drop to 35-40 psi?
l8r) |
