Something interesting that I have noticed regarding crank pressure...
Recently I have switched over to E85 and upon this conversion I have also changed my oil from 10w 30 mobile 1 to a 10w 40 amsoil . I am venting my pcv's so just by putting my hand over the vent tube, I have noticed with the thicker oil there is less air pressure being pushed out. I'm running the stock motor and cams but with HTA green and supporting bolt on mods. So with the thicker oil it seems like I am getting a tighter seal with less blow by and crank pressure?... Again this is just from a feel of hand, no real testing done. But its a pretty noticeable difference. |
Originally Posted by BluEVOIX
(Post 8862978)
Originally Posted by rodent
(Post 8862972)
The ports on the stock valve cover is way too small. Much larger lines need to be used. Even -6AN or -8AN is too small IMO. I installed two -10AN lines on mine. Since both ports are in the stock location, it baffles well and doesn't fill up my catch can too quickly. I'd take some pictures if I can ever find my digital camera. If you run a fitting on the non-stock locations it won't be baffled and you will have oil come out.
Before I went with the -10AN lines in the VC, I tried Hals vented oil cap on my last dyno. I gained 10hp! Put the stock oil cap back on and I lost 10hp which means the stock sized VC nipples can't vent enough. I am running about 630whp uncorrected so stock power they may be okay. The vented oil cap works great but lots of oil comes out and you need a catch can like Buschurs that drains back into the oil pan if you run it but with a larger -10 fitting. I welded another tube on my dip stick tube and I was considering running another catch can that just drains back for the vented oil cap only. Before I do all that, I was going to dyno with and without Hal's oil cap to see if it makes any difference with the new -10AN lines in the VC. |
Originally Posted by l2r99gst
(Post 8862939)
That's your best bet. Most people that have dipstick blowing out and crankcase issues are simply because they don't route back to the intake where the vacuum helps in relieving pressure.
Of course there are other reasons, but I think they have all been discussed already (leaky PCV, piston-wall clearance on built motors, etc). |
Originally Posted by tscompusa
(Post 8863091)
if you can run his cap for awhile draining back ill pay for your oil analysis if you're using e85. id like to know how much it dilutes it. i initially almost bought his cap until you and a few others warned me about the oil issue.
I was only going to run Hals vented cap during racing or dyno and have a valve to open/close the line and have its own separate catch can. Regular catch can will run off the VC 100% of the time since of all the water it collects. There's been other people having the same issues of water in the catch can when running E85 so its normal IMO. http://highboostforum.com/forum/show...-oil-catch-can I know the pro-bike racers run an electric vacuum to help with crankcase pressure and it gives them more power. Steve Johnson turned me on to this with his bike but I never got around to a vacuum solution. I know many racers use mechanical pumps but not much room for one of those. At least I now my engine can breath better with the larger lines and fittings off the valve cover. |
Originally Posted by Roadrunr
(Post 8854042)
Buschurs has three, a very large one also at the dipstick. It also acts as the drain back to the block when the crankcase is not pressurized.
Don https://www.evolutionm.net/forums/ve...ml#post8853606
(Post 8862939)
Of course there are other reasons, but I think they have all been discussed already (leaky PCV, piston-wall clearance on built motors, etc). Cant say much about the other reasons... |
dont used a vented catch can unless the car has speed density.
look at this. look how much it sucks air. http://www.youtube.com/watch?v=F51xymg33-w |
(Post 8863740)
look at this. look how much it sucks air. http://www.youtube.com/watch?v=F51xymg33-w One thing people should keep in mind. Lets say for example the turbo does help with sucking in the crank pressure. But at the same time, the check valve closes the exit of the other port from the intake manifold. So during WOT you only have one port open. How much crank pressure does the turbo help relieve from only one port vs having both ports venting open? |
valve cover to intake manifold
and valve cover to air intake are two separate things. the main discussion was can venting the valve cover to a catch can with a breather be more efficient then venting it to a sealed can recirculated back to a vacuum source (in this case the air intake since we have turbos) With my setup id say its safe to say recirculating back to air intake will suck out more vapors/pressure, while promoting ring sealing and other things. I was initially going to go with a 1 1/2" breather on a catch can, but decided against it after a bunch of big vendors, including FP themselves saying to run it back into the air intake. For a drag car I can see making like 3 huge ports in the valve cover and running to a massive catch can with 2 1/2" breathers on it, but not for a daily driver that benefits from the additional vacuum from a sealed setup. ------------------------ You should not get any oil blowby at the turbo side anyways, the valve cover is baffled very well and stops most of it. When I cleaned my FP intake out with wd40 it had barely any oil residue in it from over a years of boosting 30-42psi. The Intake manifold side does get a lot of oil into it when you use the stock pcv, because they fail after so much boost. usually from my research around 25psi on a evo pcv. pcv is just a one way check valve, so you can put another check valve right after it as a fail safe to stop the blowby going into the intake manifold, easy fix. ------------------------- What im doing for the intake manifold to valve cover side is: a seperate can that will separate the 2 trapping oils in the can before it can enter the intake manifold.. pretty much like a road block .. once it sees oil the can catches it then routes the air back into the intake manifold like stock setup. All I did differently here is upgraded the line to 3/8" instead of 3/4". Then I will place a check valve inbetween the catch can line that runs to the intake manifold so it can not put pressure into the catch can. So in short, im just upgrading the existing stock system to support the additional power im making over factory. hope this helps, and if i said anything wrong please correct me. |
(Post 8863766)
How much crank pressure does the turbo help relieve from only one port vs having both ports venting open? If you're not saying that and simply suggesting to add another vent for when under boost, that would be a good idea as well. But, the turbo definitely helps scavenge the pressure due to the vacuum it creates while under boost. |
with a lot of people currently running their valve cover ports to atmosphere (via a catch can and filter), is there anything wrong with just running that to the intake pipe? so both breathers are going into the intake pipe.
It just means that when you're not on boost (or just low airflow) that the crank case wont be at vacuum like the normal PCV setup... You could even do a venturi pipe in the intake pipe (like that exhaust setup) to create even more vacuum in the crank case? Cheers, Mike |
(Post 8863807)
and valve cover to air intake are two separate things. the main discussion was can venting the valve cover to a catch can with a breather be more efficient then venting it to a sealed can recirculated back to a vacuum source (in this case the air intake since we have turbos) etc.... . If your running the oem maf setup, you cant just recirculate one side and vent the other. So with that in mind, if you recirculate (sealed) back into the turbo you have to run a check valve and recirculate back into the manifold on the other end. Unless your talking about people with speed density? Now lets say you were on oem maf setup. If you keep the oem pcv setup, yes the turbo will provide vacuum but under boost the check valve closes on the other end. So you have only 1 exit port with X amount of vacuum to draw the air. Is that X vacuum through that 3/8 " hole (or what ever it is) enough or would you be better off with 2 3/8" ports venting ? Either case I like having zero oil in my manifold, intake and intercooler system. |
(Post 8863814)
You really don't want to get rid of the PCV valve, if that's what you're getting at. The PCV system is there for a reason when the IM is under vacuum as well to help scavenge excess crankcase pressure and moisture as well. Completely removing the PCV valve on an engine isn't a good idea.
If you're not saying that and simply suggesting to add another vent for when under boost, that would be a good idea as well. But, the turbo definitely helps scavenge the pressure due to the vacuum it creates while under boost. You dont need vacuum scavenging etc... You just need release. The recirculation is there just for emissions purpose and not for sealing the piston rings. I've read a lot of those articles some saying its needed and some saying its not etc... If you truely created enough vacuum under the valve cover to make that big of a difference, you will suck in a lot of oil and not as just in vapor form. The vacuum will lift the oil and when it does it will find its way around the valve cover baffles. |
(Post 8863892)
What I am trying to say is, unplug the recirculation of the pcv's and vent them all.
(Post 8863871)
So with that in mind, if you recirculate (sealed) back into the turbo you have to run a check valve and recirculate back into the manifold on the other end. Unless your talking about people with speed density? Now lets say you were on oem maf setup. If you keep the oem pcv setup, yes the turbo will provide vacuum but under boost the check valve closes on the other end. So you have only 1 exit port with X amount of vacuum to draw the air. Is that X vacuum through that 3/8 " hole (or what ever it is) enough or would you be better off with 2 3/8" ports venting ? Either case I like having zero oil in my manifold, intake and intercooler system. Im using the air intake to suck out vapors from the other catch can.. there is a dual catch can setup being used here like this: http://www.saikoumichi.com/DC3_page.htm cept with bigger inlet and outlets. i know what im doing, i put hours of research into it. |
