Originally Posted by razorlab
(Post 11743723)
So yours is like the sealed radium it looks like.
I'm glad this came up because this helps me a ton as I will soon have a working engine with a PT5858 BB attached to it. Bummer I already spent $$$$ on a STM vented can. |
Originally Posted by Chokkan
(Post 11743726)
Here's the thread with the post by ETS that was mentioned
https://www.evolutionm.net/forums/ev...58-issues.html Someone feel free to educate me :lol: |
I ran the lines the way I did because the passenger side (PCV Valve) can be made a true -10AN line to the intake. It also eliminates the PCV valve at the valve cover. Then the driver side which is a 3/8" outlet matches the intake manifold port. I put a check valve in line so it seals under boost and doesn't pressurize the crank case. You can put a catch can in line if you want. I tried welding a -10AN bung straight to the valve cover and running a vented catch can with true dual -10AN bungs off it and it started smoking almost immediately. Hooked up the system I linked before and it stopped smoking. If you weld a bung on your valve cover it doesn't matter which line you send to intake/intake manifold. They will both be the same size at that point.
- Robert |
Originally Posted by e_kobz
(Post 11743728)
I've seen that thread and I still don't undestand how what he did worked. All he did was swap the lines. There is no can in anywhere. Now instead of the PCV connecting to the Intake manifold it now connects to the intake/turbo and the crankcase connects to the intake manifold with a check valve in the middle.
Someone feel free to educate me :lol: - Robert |
Originally Posted by ETS Michael
(Post 11743758)
Essentially its the same as stock except under boost you should have more crankcase ventilation because the intake manifold side seals up under boost and solely relies on the side going to the intake. I wanted to make that at least a true -10AN if I could. So, I swapped them seeing how they matched the hose size better when swapped.
- Robert |
https://cimg6.ibsrv.net/gimg/www.evo...3a680c455c.png
I have this tscomptuned breather valve and a JB 5858. Absolutely no oiling issues whatsoever. My breather is just open with no catch can. I don't get any oil spray out of it b/c of the baffling under the valve cover. |
Originally Posted by KJS
(Post 11743887)
That is an Evo 9 valve cover, so quite different from the X. Also, JB vs BB turbo. BB turbo's are generally more sensitive to crank case pressure.
Go with the setup ETS did, and you'll be good to go. It's very simple to do. |
(Post 11744022)
(Post 11743758)
- Robert I'm looking for a flush fitting that does not have a nut on the inside of the intake (so no possibility of coming loose and taking the turbo out) |
(Post 11744175)
Robert, what fitting did you use for the intake -10AN? looks like you drilled a hole into the intake and put the fitting in.
2 Attachment(s)
(Post 11744182)
That's the ETS intake pipe, it comes with a bung welded in that the fitting threads into. No nut on the inside of the pipe, but a bung needs to be welded in if your intake doesn't already have one.
You can even see the white sealant on it. I think it's a bulk head fitting. I was just curious which one he used. Attachment 261631 Attachment 261632 |
Crankcase pressure problem on EVO X ?
Throw one of these at it: https://www.c-f-m.com/performancepar...iart-p1370.htm ~Jaraxle |
Originally Posted by Jaraxle
(Post 11744240)
My PCV is still stock
