I removed a bunch of sound deadening material from the back of my Eclipse. Hammer and chisel is what I had to use too. LOL
Looking good so far! Any updates over the last couple weeks? |
Originally Posted by bakuro117
(Post 11215214)
Looking good so far! Any updates over the last couple weeks? I'm trying to be patient as he's one of the few automotive welders/fabricators in my area who I am confident can do this properly. |
Originally Posted by doncarbone
(Post 11215959)
Unfortunately the guy I paid to do the fabrication has been very busy and continues to need to postpone when we will have this done. His best estimate is the middle of June.
I'm trying to be patient as he's one of the few automotive welders/fabricators in my area who I am confident can do this properly. Patience is key if you want something built correctly/usable at all. Hang in there, buddy. |
Originally Posted by xmaster19
(Post 11216040)
Trying to take short cuts or cut corners will always end up with you needing to fix a 1000 things or you having to do it all over for a second time.
Patience is key if you want something built correctly/usable at all. Hang in there, buddy. Oh well... the time will come eventually and I'll make sure I get many, many pictures and explanations of what is involved. |
Kinda my main question is, do you know if doing a swap with some good friends would be too difficult. I read up some more and found this
http://www.lltracing.com/dohc-conversion.html With a whole kit like that and good tools you think it would be manageable? My friend has a shop and just pulled off his new Honda's motor for his 5 speed VTEC conversion. Other friend has his eclipse head off. This may be a route I would take. |
Originally Posted by JaMRxHanzoxOZ
(Post 11217221)
Well this site has the 4G92 Engine that wasn't made in america. Its a direct FWD 2.4 MiVEC bolt on. No need to add the awd difficulties into the process. Comes with everything I would need supposedly. I've been talking to someone from LLT on Facebook about what this all entails. He said it includes all the parts necessary.
(Post 11217422)
If you can get a hold of the DOHC version of the 4G92, maybe it'd be a worthwhile upgrade. Someone here I'm sure can provide pros and cons of going this route. The 4G69 2.4 that I swapped into my car, by the way, is more commonly used with a FWD transmission than with AWD... In fact the AWD version is quite rare and to my knowledge only available in the Mitsubishi Outlander (and if you want 5spd, you only have a 2005 or 2006 Outlander to choose from). I had the FWD transmission in my car for about a year before I decided to go for broke and try out the AWD swap. |
And the 4G69 engine, is a DOHC MiVEC? What did you need to source out other than that motor? Should I just read your thread haha. I'm hoping that I can snag a list of things. I'm awful when it comes to engine work.
(Post 10761779)
SPAL radiator fans arrived today.
P/S pump + hoses and the correct motor mount from Mitsubishi should be here tomorrow :D |
(Post 11218380)
I've been reading this whole thing (bored at work, I work nights 1030-630am) but yeah all you really needed were the 4g69 parts and the rrm motor mounts with a ralliart #6 upper mount? There is no chance of using a 94 tranny? Could I just order the set of them for the ralliart off rrm? Or is it only one. And what... is a P/S pump... lmao
For the 4G69, I needed the ancillary components as the 4G94 accessories require a 4 rib belt, whereas the 4G69 uses 5 rib. This is a bit of a pain and one of the disappointing factors of this particular swap. You could probably convert the 4G94 accessories to work with a 4-rib if you sourced the right pulleys, and I can't remember but you might also need new brackets too for mounting, but for what it was worth, I just sourced a used Ralliart P/S pump (power steering pump), used A/C compressor (which has since been removed), and bought a new alternator. Only the passenger side upper mount needs to be sourced as far as motor mounts go. The rest of the mounts between the 4G94 and 4G69 are the same. You'll need the throttle position sensor and cables as the 4G69 has an electronically controlled throttle body which the 4G94 does not. You will also need the 4G69 ECU and engine harness. A 4G94 transmission will not bolt up to the 4G69 either as far as I know. |
(Post 11217422)
Seriously, the RA's torque make it really easy to drive in city, perfect for a DD. I live in the mountains so there is always a hill to climb. I wouldn't want to lose that. Also, I'd be curious to see how much the tall gear ratios of the trans work with a smaller engine. The 4G92 has 39 lb.ft of torque less than the 4G69, don't know how well that would do with the RA trans gearing... |
(Post 11219319)
I wouldn't do all that work and spend all that money for 10hp and quite a lot less torque from the smaller displacement. Want something revvier than a 4G69?? Destroke the 4G69 and voilà!
Seriously, the RA's torque make it really easy to drive in city, perfect for a DD. I live in the mountains so there is always a hill to climb. I wouldn't want to lose that. |
I was searching randomly on Google and found out about your project...mad props for your OZ, the cleanest OZ I saw to date...I red all thoses 16 pages, that is an amazing walkthrough and a lot of quality info, you say that you ditched the a/c, my question is what type of belt did you use to still work with the auto tensioner ,I'm ditching the A/C too even tho it's gonna hot as hell in Montreal this summer.
Originally Posted by MaxG_R//A06
(Post 11227362)
:beer:{thumbup}:beer: |
