another evo project
Old Feb 24, 2012 | 03:43 PM
  #106
JTEVO2932's Avatar
looks great man, cant wait to see more!
Old Feb 27, 2012 | 04:48 AM
  #107
mrboost05's Avatar
thanks ^^^ over the weekend i had a chance to dig into the wiring to depin some of the wires is a pain in the *** others just pull right out so far all i worked on was the abs wiring and there is a ton of it.
also if anybody has the center counsole please let me no i was not paying attention and i depinned a wire i dident need to i now need to see where it goes in the connector its a blue coonector that sits on the driver side under the shifter console wires white/black thanks.
Old Mar 8, 2012 | 09:19 PM
  #108
mrboost05's Avatar
has anybody removed the oem fuel lines before ? the hard line that runs from front to rear.
Old Mar 9, 2012 | 04:10 AM
  #109
ttp's Avatar
ttp
I like a clean style
Old Mar 21, 2012 | 07:26 PM
  #110
mrboost05's Avatar
looking for some help on another small project anybody good with electronics
anybody know if i can cut this where the lights use to go in without it effecting anything else
Old Mar 21, 2012 | 07:31 PM
  #111
JTEVO2932's Avatar
No I havent, but if you have a lift and the time, Im sure you could get it done. Why do you want to remove them?
^^That looks good!
Old Mar 22, 2012 | 12:26 PM
  #112
mrboost05's Avatar
^^That looks good!
thanks jt i still gotta little work to do i wanna be able to see the hole gauge as for the oem lines i am not using them i have a double pumper with a -8 feed and -6 return so they are of no use and i dont like the fittings just sitting in the bay.
Old Mar 24, 2012 | 02:10 PM
  #113
mrboost05's Avatar
finally got the fuse box mounted turned out pretty good for not removing the dash gotta run wires and find a good spot to mount the ecu and extend a few wires.
Old Mar 25, 2012 | 04:59 AM
  #114
importmachine's Avatar
Wow, I really like where this is headed ... show us some full car shots. GL with the Build too
Old Apr 9, 2012 | 07:50 PM
  #115
mrboost05's Avatar
getting there guys should be running by the end of the week there are no wires that run from the drivers side anymore only the hood latch cable so i had to extend the side marker the srs and the 3 plugs for the head lights the head light harness now runs thru the rad support.
Old Nov 25, 2012 | 09:55 PM
  #116
mrboost05's Avatar
Well i am back at it this winter i have alist of things to knock out this winter to catch the thread up last year in march i blew the motor i thought it was just the head gasket i ended up taking a a few chunks out the head killing the rod bearings and more so i had stm put a used bottom end in the car just to be able to drive it for the summer it i cant say enough good things about them and i am pass do on a good review but i plan to do it soon.
plans:
LR2.4 motor or buschur 2.3rpm
Aem v2 tune from emery
spark tech pro cdi
new catch can setup(havent decided yet on placement)
powder coat valve cover /brakes and a few other random engine bits
fix a few things on the harness
apexi coilovers
engine bay as of now
outside as of now this was at the shootout with dave B car in the back
Old Nov 27, 2012 | 03:41 PM
  #117
thepoint4life23's Avatar
Saw the car at the shoot out the car is sexy makes my white 8 look like poo. The white Coated Breaks are hot.
Old Nov 27, 2012 | 03:57 PM
  #118
Mistaken's Avatar
Nice build!
Old Nov 27, 2012 | 10:42 PM
  #119
maxd's Avatar
Wow nice build man, both last one and this one.
Old Nov 29, 2012 | 05:02 AM
  #120
mrboost05's Avatar
I think i am going for a color change on the brakes and valve color something to make it pop alittle more and that was my 2nd shootout but my first time with the car even on a hurt motor i had tons of fun thanks guys calling stm to order a few things today motor pull starts tomorrow.
